11-23-2006, 07:50 PM | #1 |
Rock Crawler Join Date: Aug 2005 Location: White Lake
| shock weight oil help!!
I have the t-maxx aluminium shocks turned upside down on my tlt. I have is I run 15 weight all the way around with losi yellow springs on front and red losi springs in back. I use to run 25 weight all around. My problem is when I f;ex the rear tire stays on the ground, and when I crawl it I flip sometimes because I don't have all the tires on the ground, please help!
11-23-2006, 08:18 PM | #2 |
Pebble Pounder Join Date: Nov 2005 Location: huntsville
I tried running 15 once. I think it was actually TOO thin. It seemed like it didn't have enough lubrication to keep the o-rings in the shocks from sticking to the shock shaft. I swapped back to 30 and all is well.
11-23-2006, 09:01 PM | #3 |
I might try that tpmarrow since nothing to do and thanks!!! and is that all four shocks?
11-23-2006, 09:08 PM | #4 |
i run 20 in 3 of them and 50 in the left rear... to couter the twist, although my truck has very little twist anyway.
11-24-2006, 07:25 AM | #5 |
Quarry Creeper Join Date: Jun 2006 Location: Pinckney
I run losi yellow springs up front, with 20wt oil. Right rear is 35wt oil, and a traxxas Stampede front spring, Left rear 50wt oil, ans the matching stampde spring. I think I got this set up from BENDER??
