Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: BB lockers
Old 11-29-2006, 04:26 PM   #1
Default BB lockers
Stick 3 regular bb's inbetween each spider gear in your diff and its locked.
viper7016 is offline   Reply With Quote
Old 11-29-2006, 04:33 PM   #2
interesting that may be a good idea to do if you do the spider gear trick put some in there to keep starshaft from breaking...interesting idea
Got Rocks? is offline   Reply With Quote
Old 11-29-2006, 04:45 PM   #3
Pics??
jamesbernatchez is offline   Reply With Quote
Old 11-29-2006, 08:49 PM   #4
Um..... I seriously don't feel like taking and posting a pic. Just put all your gears in then cram in as many bbs as you can fit and then stick it together.
I tried to spin the axles with my hands and it seems pretty locked, however when the bbs get in just the right spot it will slip just a tiny bit. I think over time it will eat away at the bbs or gears or both. But if that happens then I'll just JB it.
Old 11-29-2006, 09:41 PM   #5
I don't think your gears will like those bb's for very long.
Soya is offline   Reply With Quote
Old 11-30-2006, 08:07 AM   #6
yes, in metal vs. plastic- metal always wins. Good idea though; I would love to see a better solution to lockers than jb weld (or spending anymore $$ on this rig!)
matt
cincy
mrpink is offline   Reply With Quote
Old 11-30-2006, 09:07 AM   #7
Whats wrong with JB?
Canadian Crawler is offline   Reply With Quote
Old 11-30-2006, 09:27 AM   #8
the only thing I am can think of is the fact that it is not reversiable; I do not see a need or desire to reverse it true, but I would like the option if there is ever a better way developed.
matt
cincy
Old 11-30-2006, 09:30 AM   #9
matt
cincy
The TLT's have pot-metal diffs, not plastic diffs. It is a good idea though. But instead of a bb maybe somthing else
mike is offline   Reply With Quote
Old 11-30-2006, 03:18 PM   #10
what about those ultrasonic airsoft bb's?
matt
cincy
Old 11-30-2006, 04:07 PM   #11
matt
cincy
I would think that they would get chewed up quick. Try it and let us know
The best thing I could think of to use that is reversible would be small pieces of hard metal in various sizes, so that it can get inbetween the teeth and prevent them from moving. With the bb's only the very edge of the gears are touching the bb's.
I have driven it in my room on carpet (high traction surface) and some bricks with 4ws for about an hour with no problems yet.
Old 11-30-2006, 09:00 PM   #12
actually the easiest way and mmost reversable way is hot glue. it gives jsut a little bit and helps prevent the axles snapping to some extents but also even when locking the my own diffs I messed up once it was cool I could just rip it out and do it again. it works awsome.
guy45 is offline   Reply With Quote
Old 11-30-2006, 09:09 PM   #13
will hot glue hold up to a BL motor setup running through a R2 trans? seems like it would be a weak link in the system- maybe a good thing; keep s**t from breaking.
matt
cincy
Old 11-30-2006, 10:28 PM   #14
BB's are waaay stronger than those crappy gears.
Old 11-30-2006, 11:22 PM   #15
Why not just JB weld it. Who cares if you can't reverse it. It's a few bucks to replace it. Anyway why in the hell would you want to undo it? It's a crawler and thats what it will always be. Just my thoughts...But what do I know.
Old 12-01-2006, 05:37 PM   #16
stuff the entire case with steel wool.
Mr Badwrench is offline   Reply With Quote
Old 12-01-2006, 06:13 PM   #17
I just did the spider gear swap, I'm going to stick with that untill something breaks in there.
I don't think the potmetal will hold aginst the bb's.
xjman is offline   Reply With Quote
