02-04-2005, 09:57 PM | #1 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
| Who has a Pajero?
I'd like to build a scale rig, and not spend a whole lot of money. So I was thinking Pajero. I understand the tranny and front end are molded into the chassis. I was wondering if I could somehow separate them and build myself a custom chassis and new a-arms. I've seen it where people chop the chassis in half and stretch it. Is that the best way to go? I don't want to cut it up and ruin it. Also curious about what drive shafts to use on the rear when stretching it. |
02-04-2005, 10:05 PM | #2 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
Do I need to revoke your star??? Need to search a little. A pajero thread started just last week. It couldn't have gone far... If you're going to go through all the hassle of cutting and extending and such, get a TLT. |
02-04-2005, 10:28 PM | #3 |
Well, I dont want to spend a bunch of money. If I could find a cheap Pajero I wouldnt need a new tranny and stuff.
02-05-2005, 12:03 AM | #4 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
It's all alot of "depends on what you want to do" Pede or max shafts work So does max turnbuckles So it's alot like building a TLT-only on one side. Also when it comes to the front you cant do alot-dont plan on putting a pajero on swamp dogs unless your willing to hack some stuff. |
02-05-2005, 09:42 AM | #5 |
Quarry Creeper Join Date: May 2004
the pajero is actually around 230 and the tlt is around...110? so the TLT would be cheaper
02-05-2005, 02:45 PM | #6 |
not if i found a used one
02-05-2005, 03:20 PM | #7 |
Rock Crawler Join Date: Jul 2004 Location: Mt.View CA
You can put swamp dogs on one you just have to use your noggin.I lifted mine with my 3/4 " lift and i can fit 2.2's without hackin up the chassis or fender wells.also for drive shafts i cut mine in half and welded a exstention in.the biggest problem to modding your IFS is dogbones which i custom made mine,good luck though ,they are alot of fun to work-on/drive.
02-05-2005, 08:40 PM | #8 |
Rock Stacker Join Date: Feb 2005 Location: Medford
I have a cheap Pajero ! All it needs is a new chassis (cracked and un-repareable). Since it is the same chassis as the tourag and new pajero, you should be able to get one. Other than that the rest of it is in great shape. $ 50 and it yours ! |
02-05-2005, 09:00 PM | #9 |
thanks bud. YGPM
