12-21-2006, 02:42 AM | #1 |
Newbie Join Date: Dec 2005 Location: vero beach
| Throttle Response
1. Just finished building my first tlt crawler but it seems that the throttle response is a little jumpy when going forward,... not having that problem in reverse. Im using a Traxxas reciever and the Tekin2 esc. Would that just not be a good combo together?
12-21-2006, 09:27 AM | #2 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
esc act differently in reverse than forward. You may have soldered the motor backwards causing the esc to go in "reverse" when going forward. Look and make sure everything is wired correclty, if not fix the wireing, then you will need to reverse the throttlte on your controller
