01-09-2007, 03:37 PM | #41 | |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
01-09-2007, 04:54 PM | #42 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
Thanks guys, The receiver is inside a project box from Radio shack. The cover has a inside lip, I cut out the lexan so the cover could fit inside the cutout. Then I notched the lower box for the wires, and bolted it up. The Quark esc is not protected yet, but that will probably go inside a small box as well. Cole, you can direct your truck away from those gates, I am sure Tyler could give you some excellent pointers |
01-09-2007, 05:00 PM | #43 |
RCC Addict Join Date: Apr 2006 Location: Minnehopeless
| It looks good.... but you could have at least cleaned the tires for the photo shoot |
01-11-2007, 06:25 PM | #44 |
Kevin, you are more then welcome to clean my tires :-P I was asked how i mounted the skid plate, so I took some pictures. And while I was taking pictures of the skid plate mounts, I also took a couple of my BTA setup. I made the carbon drag link at work, just incase anyone was wondering about it. |
01-16-2007, 09:34 PM | #45 |
Beadlocks finally came in I know people say that the mashers do not work well with the beadlocks, but they seem like a good fit to me. I guess I will have to run it, and see if they slip. If they do I will shim the bead, or figure something out. |
01-17-2007, 04:09 AM | #46 |
| If those rims don't work out, I'll take 'em off your hands. |
02-03-2007, 11:04 PM | #47 |
Painted up one of the beadlocks today. I will do the same with the other ones soon. |
02-26-2007, 10:39 PM | #48 |
Finally finished painted the rest of the rims.... I also machined the edge of the rims down a bit, to better hold the masher tires. |
02-26-2007, 11:23 PM | #49 |
Truck is looking real good. How much do you think you machined off the rim? My mashers haven't slipped yet, but I have to take care when mounting them, so they don't. Machining a little off the rim makes a great solution.
02-27-2007, 07:55 AM | #50 |
Thanks, I think it was around 1.2mm's that I removed from the first one. The rest of them I eyeballed.
02-27-2007, 10:02 AM | #51 |
Newbie Join Date: Sep 2006 Location: middle of nowhere
haha i love the rear shock mounts....... you can do better than that... how about shock mounts.... lol well whatever floats your boat. nice rig btw i want to build one of those sometime
02-27-2007, 10:09 AM | #52 | |
02-28-2007, 09:29 AM | #53 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
I think the rig looks really good. And the shock mounts look great to me. Does your rig ride in the shocks quit a bit? |
02-28-2007, 11:33 AM | #54 |
Thanks, it is setup with droop suspension. They have zero up travel. I figured that was the best way to build a belly dragger tuber.
02-28-2007, 03:40 PM | #55 |
that is really cool. This made sound stupid but i am still learning about suspension etc... but do your shocks even run springs. I know there is none on the outside, but maybe you have a super soft spring on the inside? Thanks for answereing my q's, i assume it crawls alot better with a low cg. Last edited by Rc EnthuSiasTs; 03-16-2007 at 05:43 PM. |
03-01-2007, 03:59 AM | #56 |
| With droop suspension there are springs inside the shocks to keep them compressed. They fit on the shaft. |
03-15-2007, 12:06 PM | #57 |
Pebble Pounder Join Date: Feb 2006 Location: Mankato, MN
OOOO man. Really nice job Mike. Now I wish I had the time to build one. The only thing is. I dont know the first thing about building one.
03-15-2007, 04:21 PM | #58 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
nice build! the tube frame shape looks a lot like an old grasshopper body!
03-15-2007, 10:02 PM | #59 | |
RCC Addict Join Date: Jan 2007 Location: San Jose
I know for the outside I am just making custom springs from scratch to reduce torque twist, but i have yet to figure out the inside which i plan to do. Thanks. | |
03-16-2007, 09:31 AM | #60 |
They were just springs I had from something else, I didn't have much luck with mini-T springs as they didn't fit. Its slim pickings for small springs that are soft enough.
