01-15-2007, 03:19 PM | #1 |
Newbie Join Date: Jan 2007 Location: charleston
| diff noise???
ok im new to rc crawler so dont shoot me down to hard but i got a couple of ?? does anyone have problems with diff noise because when i give it full throttle it makes an awfull noise in the rear kinda like a vibrating noise but only at full throttle the truck is only about a week old no diffs are locked except the center one ,im running a venom fireball 19t double is that to much power for it any help would be appreciated.
01-15-2007, 03:40 PM | #2 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
take it apart, it should be obvious what the issue is. Did you grease the gears? shim the gears? First axles I built I lightly greased them and they wore out very quickly. give the ring and pinion gears a large supply of grease and shim the pinion into the ring gear a bit(.3mm) with some shims it will make the gears last longer. |
01-15-2007, 03:54 PM | #3 |
i have taken it apart and i had the diff locked and i unlocked the diff inspected the gears loaded it up with grease and put it back together and it still did it so you are saying i need to shim the little gear thanks
01-15-2007, 07:33 PM | #4 | |
