01-22-2007, 07:32 AM | #21 | |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
01-22-2007, 08:47 AM | #22 |
Rock Crawler Join Date: Dec 2006 Location: Southern California
hi. nice rig i really dig that body even though i hate yotas but it look sweet.i have made my own bmv2 and i know its smaller than the original.but i get a lot more flex from mine then all of the bmv2s that i have seen.i get 4 3/4 inches on the front and a hair ove 5 on the back. so i was wondering y????
01-22-2007, 08:52 AM | #23 |
hey i forgot to tell u. i run the same style batt on mine and i placed it on the same side as u but insted i stood the batt up on its side and siptied it to the tranny plate.and it does not restrict my flex at all.i hope this can help.
01-22-2007, 12:00 PM | #24 |
I got to drive it some this morning. I definately have to modify my driving style from my other rig but near vertical stuff was awesome! There were a couple moves that I have figured out with my other rig that I couldn't do with this but I think its more me than the truck. That being said I will run my J2-tt at the comp for sure but mostly because I know it better.
01-22-2007, 01:16 PM | #25 | |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
01-22-2007, 02:17 PM | #26 |
Yeah, I too am adding weight (strategically) to my BM-VII. But it's easier to add weight down low than to try and remove it from from places it can't easily be removed. |
01-22-2007, 02:20 PM | #27 | |
01-22-2007, 02:21 PM | #28 | |
So is the BMVii too light? I guess we can try to make the axle plates out of steel.... | |
01-22-2007, 02:31 PM | #29 | |
I weighed my rig just a few mins ago (brought it with me to work) and I'm at 6.5 lbs with a sub C pack so far, balance is about 60/40 towards the front. How heavy are the rest of you ending up? I found that's enough to cause some droop where I want it for going up hills. Less up there and it seems to twist and rebound back. | |
01-22-2007, 02:34 PM | #30 | |
I would rather have it to light and add the weight down low were it will help. Mine ready to crawl set up w/ a lathe motor, 8 cell battery, RC4WD bead locks and the Badlands tires is 5 lbs 11 ozs. Change that to a BL motor, 2.2 in Mashers and HPI wheels And I'll bet it's well under 5 lbs. easy. Last edited by dezfan; 01-22-2007 at 02:41 PM. | |
01-22-2007, 02:37 PM | #31 |
Newbie Join Date: Jun 2006 Location: moundsville
looks cool but not very much flex with it, id slide the tranny forward to get a bit more flex out of it dave |
01-22-2007, 03:05 PM | #32 | |
I am planning on moving the tranny farther forward but I have to get a different battery first. | |
01-24-2007, 11:25 PM | #33 |
So I got a 6 cell tamiya 1700 triagle shaped batter that works much better and looks better too. I moved the tranny forward. I added about 2 oz of weight to each tire which has increased flex some, I now get about 3.5" where I was getting about 2.75". So I finally got some real run time with it today. First impressions are that its a very capable rig, verticals are great!. Smooth side hills are very good and the low profile actually lets you get under stuff. I know getting under stuff sounds weird but its fun to sneak under overhangs that other rigs have to go around. This chassis and I assume any torsion chassis has a tendency to sling-shot the crawler into a roll over in the right circumstances. I wish there was some way to add some damping to it but I can't think of anything. In all I am very happy with it. It is fun to have something so different than my other crawlers and it makes you learn a new driving style which is cool too. |
01-25-2007, 01:38 AM | #34 | |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
no he has 3 on backwards! | |
01-25-2007, 01:44 AM | #35 | |
actually by making the axle plates out of steel he would be adding the weight to the axles where you want it! | |
01-25-2007, 08:45 AM | #36 | |
Wheel weight is still better than steel plates though because is is centered on the mid line of the axle and the plate is slightly above the axle. | |
01-25-2007, 08:48 AM | #37 | |
01-25-2007, 10:59 AM | #38 | |
Rock Crawler Join Date: Jul 2004 Location: OC, Oregon
01-25-2007, 05:53 PM | #39 |
Here's a picture with the new modifications. |
01-30-2007, 09:04 PM | #40 |
So I let my friend borrow this rig to compete at the last UTRCRC comp. He took third with a little luck. but just a little. He was the second to even run the courses and had only driven it around for 5 minutes in my living room the night before. I think it goes to show how good this rig is. With more time with it and knowing the rules better it could be scary how well he does. I have decided I am going to continue with my j2-tt for my main rig but I also have more driving time with it and have spent hours and hours tweaking the set up. That is one of the best things about the bmv, set up is very simple. If the course is right though, who knows, maybe I'll run the BMV. I drove the bmv around for a while after the comp and was very impressed. Especially because I have approximately half the $ in this one. If you want a very competitive crawler, for a great price, that is easy to set up you absolutely cannot go wrong with the BMV! It took a couple of big tumbles and held up fine. |
