02-13-2007, 08:22 AM | #1 |
Pebble Pounder Join Date: Aug 2006 Location: High Point
| is this right?
i put together my axles yesterday, they are really hard to turn, is it because i am useing the stock bushigs? plz help |
02-13-2007, 08:33 AM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Make sure you installed the outer knuckles correctly, if they are upside down they'll bind.
02-13-2007, 08:56 AM | #3 |
even w/o the knuckles they are hard to turn, the knuckles are correct, the servo works the wheels, and the linkage is far away from the axle housing, did i use enough cramic grease? maby i have the cases to tight, every thing was free until i chinched the screws down...how tight should they be? thanks for the help bender. |
02-13-2007, 09:01 AM | #4 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
Did you use any shims when you put the pinion in? I usually use alot of grease on mine and I highly recommend getting bearings, not only will it roll smoother but the internals of the axle will last longer.
02-13-2007, 09:11 AM | #5 |
i didnt use any shims, i pulled them and threw alot of grease in there, its a little smoother, but still feels like something is binding. i pulled the knuckles, and its still there
