02-17-2007, 11:15 AM | #1 |
Newbie Join Date: Nov 2006 Location: Temecula
| TLT Crawler
Heres my TLT crawler I have been working on the past few weeks. I mounted the shocks on the lower links like Clods because I couldn't find anywhere else to mount them. |
02-17-2007, 12:07 PM | #2 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
that looks great its one of the cleanest TLT's ive seen in a while! Good job. |
02-17-2007, 12:23 PM | #3 |
Rock Stacker Join Date: Jan 2007 Location: some where
looks sweet
02-17-2007, 12:46 PM | #4 |
Quarry Creeper Join Date: Jan 2007 Location: New York
should be a good hill climber, and i spot a pede in the corner..... missing the rear end!!! looks good though!
02-17-2007, 01:06 PM | #5 |
Thanks for the words everyone! And BTW, Snail, that is a Rustler with a custom made lexan chassis! I'm gonna convert it to inboard motor too. It's crazy fast with a Mamba Max 5700, and wheelies are crazy! To bad I stripped my differential gear though.. Also, if you're wondering where I got that chassis, I built it. It's cut out from a Savage TVP, I guess you could say I'm useful with what I got. |
02-18-2007, 09:14 PM | #6 |
I have some pics here with tires on. I am going to use M2k's but not these ones. I have a question though for the crawler weight gurus. Would mounting the battery (IB1400 6 cell) on the rear axle servo mount be bad? There will be no servo so it will be lower than up on the front servo. |
02-18-2007, 09:34 PM | #7 |
Newbie Join Date: Jan 2007 Location: San Diego
Great build, I like it so far. I tried the batterys in the back as well and didn't like it, I'm no crawler veteran by any means but I found that mounting them on the front servo helps the break over and mine crawls alot better with the batterys mounted forward. Again sweet build and keep those pics comming. |
02-18-2007, 09:49 PM | #8 |
I ran my batt on the back for the same reason you mentioned. I just had to add a bunch of weight to the front axle to get the bias back to the front.
02-18-2007, 10:02 PM | #9 |
Quarry Creeper Join Date: Nov 2006 Location: Lexington Park
nice build! very nice cog. i think you should leave the battery where it is. its not that high in the air. it still looks below the tires and its good to have the weight toward the front. good work. i want to see a video when your done. what is the wheel base? |
02-18-2007, 10:35 PM | #10 |
The wheelbase is at just around 12.5. I think it's a little bit less though. I'm not looking to run this in comps, just for a little back yard fun. BTW, this is what I got to work with. http://www.ultimaterc.com/gallery/di...bum=159&pos=38 http://www.ultimaterc.com/gallery/di...bum=159&pos=42 Don't mind the Savage, but look at those rocks! They are kinda slick though... |
