02-19-2007, 10:43 PM | #1 |
Rock Crawler Join Date: Nov 2006 Location: Spanish Springs, Nv
| SW2 body mounts
what are good body mounts for the SW2?
02-20-2007, 05:33 AM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: colchester
good question i would like to know too
02-20-2007, 05:37 AM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Depends on your body, but I used the TLT ones with no problems. Losi also sells some that work with the hole spacing on the SW2. These are both for top mounting, don't know about side mounting options.
02-20-2007, 06:28 AM | #4 |
Rock Crawler Join Date: Aug 2005 Location: salunga
well if your using a body w/ flat sides like a bronco you can run posts out the sides. or what I did on both of mine was to cut pieces of delrin rod to the length I needed than I bolted a plate to them and just attatch the body w/ velcro. this way you don't have any post or bolts sticking out thru the body to get hung up on, or crack your body out. if you want I can post some pics when I get home from work tonite. Last edited by sods; 02-20-2007 at 05:22 PM. |
02-20-2007, 07:27 AM | #5 |
^^^^^^^thats a good idea. im gonna have to try that. could you post some pics that would be awesome
02-20-2007, 09:34 AM | #6 |
yea, can you post some pics? How does the velcro hold up in a rollover? ERIN, do you know what Losi body mounts they are? Thanks
02-20-2007, 09:53 AM | #7 |
Parma generic body posts come in many lengths starting at like 1.5" up to like 5" in half inch increments...made in USA, black plastic, drillable for side or top mounting and easily trimmed to length.
02-20-2007, 11:20 AM | #8 |
RCC Addict Join Date: May 2005 Location: I live Here
i used the stock tlt for the hood and the hpi ones for the rear i didn't like and want the side post look take into consideration that i used the hpi rubicon body |
02-20-2007, 05:45 PM | #9 | |
02-20-2007, 05:56 PM | #10 |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
I'm going to do a variation on the velcro type set up. I'm going to have posts comeing off the chassis like above, but with thin aluminum angle bolted to it. The angle will let the body rest on it and I'll probably use some small screws to attach it...the weight will be held by the angles. I'd also like to use the angle to mount some "rock sliders" to, but mine will probably end up looking like a simple nerf bar! |
02-20-2007, 07:09 PM | #11 |
thanx sods that looks like it would work good. i think im gonna try that and see if i can get it to work in my favor
02-21-2007, 06:05 AM | #12 |
no problem xj, glad I could help out.
