02-26-2007, 12:21 PM | #1 |
RCC Addict Join Date: May 2005 Location: I live Here
| Link material
I did a search on delrin vs. aluminum links there is no actual thread that i could find so the question is what are the pros and cons of havinf your links in aluminum or delrin ? ? ? Thanks |
02-26-2007, 12:25 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I run Delrin links on everything now. The Delrin glides over the rocks, it's light and it has a little give for hard rollovers. The slight give in the links usually helps to save other parts from breaking during the harsh rolls. Plus the Delrin is alot easier to work with, then aluminum.
02-26-2007, 12:31 PM | #3 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
i am going to make some delrin links for exactly the reasons bender said. the alum is soft so sharp rocks dig into it and hang up. and with a delrin link you can turn down the end so its the smae size as the rod end. only hard part i guess is center drilling the solid rod |
02-26-2007, 12:36 PM | #4 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
I run 8-32 all thread rod sleeved in 1/4" delrin tubing with jato rod ends. The best of both worlds imo. Super stong and still super slick, plus you can run a smaller diameter delrin tubing and still have them be stronger than solid delrin links of a larger diameter, and you get a little more clearence too. |
02-26-2007, 12:42 PM | #5 |
That's a good method too. ^^^^
02-26-2007, 12:46 PM | #6 |
thanks for the info guys delrin here we go
02-26-2007, 01:11 PM | #7 | |
I joined the Band! Join Date: Feb 2007 Location: San Diego
Nice new chassis Bender. By the way, where is the place to get Delrin rods and / or plates? Quote:
02-26-2007, 01:13 PM | #8 |
i just get mine already made at http://www.xtreme-rc-hobbies.net/ ask for DAvid he is bad *** ! ! ! ! |
02-26-2007, 01:14 PM | #9 | |
You can find Delrin at local plastic distributors, or online at www.mcmaster.com shipping can be expensive though. | |
02-26-2007, 01:52 PM | #10 |
Rock Crawler Join Date: Sep 2004 Location: eureka
a great alternative to alum. is stainless , that's what i use slides over the rocks real well. i would use derlin if you could though, for all the reasons everyone stated
02-26-2007, 02:06 PM | #11 |
Pebble Pounder Join Date: Aug 2006 Location: Albuquerque
US plastics sells all sorts of rods/tubes/sheets. They are reasonably priced and shipping is manageable. They also don't mind dealing with small orders. www.usplastic.com |
