03-06-2007, 03:54 AM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: Enterprise
| tlt axles and All-ts
A buddy of mine just picked up a RTR tlt tuber off of ebay with 2.2 imex all-ts on it. I was just wondering since the 2.2 all-ts are about the same size as a typical maxx tire, will they hold up okay?
03-06-2007, 08:10 AM | #2 | |
Newbie Join Date: Dec 2006 Location: Hillsboro
BTW....I run All-T's on my TLT and have broken axles. You just have to learn to drive a little easier with them. | |
03-06-2007, 09:47 AM | #3 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
what are you breaking? Just curious cuz i either break a bevel gear, or i just recently broke a stub shaft. |
03-06-2007, 10:04 AM | #4 | |
I've never broken a bevel gear, though have stripped one nor have a broke a stub axle. The CVD's should cure the problem for the most part since they will be one diameter through the length of the axle. It should make for a much stronger axle. However, finesse driving can limit the damage done to a TLT when running bigger tires, but breakage will still occur. Using speed and power with big/heavy tires leads to a lot of broken axles. | |
