04-29-2007, 12:15 PM | #1 |
Rock Stacker Join Date: Dec 2006 Location: Dark Side of the Moon
| my TLT tracer build
this is my first TLT Tracer build. its just a RTR kit from Rccrawler.com with upgraded shocks. 45t with a 12t gear Tracer frame stock tranny with dual belt tensioner moabs bronco body finally got the stock tranny working pretty well and just painted the body so here are a few pics before it gets all marked up. need a little final sanding and it will be done ramp test and a few with the body. no action shots with the body striped out my spur greag the other day. painted after my 1:1 |
04-29-2007, 02:19 PM | #2 |
Quarry Creeper Join Date: Feb 2007 Location: East Aurora
looks nice, how well does this chassis crawl?
04-29-2007, 02:39 PM | #3 |
I have been pretty happy with the way it crawls, but all I have used it on so far is a pile of paving stones I have. and its doing better since I have taken the springs out of the shocks.
05-01-2007, 11:47 AM | #4 |
RCC Addict Join Date: May 2005 Location: I live Here
what pitch are on those gears ? ? ? i want to upgrade gearing on a tracer |
05-01-2007, 11:51 AM | #5 |
Quarry Creeper Join Date: Apr 2007 Location: .
that body makes it look sweet. also the colors look soooooo identical |
05-01-2007, 03:34 PM | #6 |
05-01-2007, 03:51 PM | #7 |
45t with a 12t gear where do you get these for the stock tranny ? ? ? |
05-01-2007, 03:59 PM | #8 |
my bad the 45t is the motor. I'm not really sure of the pitch its the stock spur and a 12t on the motor. they should work. |
05-02-2007, 08:45 AM | #9 |
did you do any mods on the motor mount fo it to slide ? ? ? what 12t did you use ? ? ? a tamiya 12t or the robinson ? ? ? |
05-02-2007, 04:26 PM | #10 |
yes its the tamiya gear and yes i had to slot the opening alittle. I need to go back and open them a little more because I think it sliped and that is how I ate some of the theet off of the spur.
05-10-2007, 05:43 PM | #11 |
finally got my new gear in. nits a 83T and I have a 12T on the motor. and looking at it again I had to grind/ sand the plastic housing and not the metal motor mount. so a tamiya spur gear should work, but I went to the hobby store and had the guy look it to be sure. hope that helps
05-11-2007, 10:01 AM | #12 |
do you have a link to that 12t pinion you got ? ? ?
05-11-2007, 11:47 AM | #13 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
How did you do your belt tensioner??
05-11-2007, 04:05 PM | #14 |
about the gear I dont have a link. I went down to a the hobby store and made the guy look it up for me. as far as the pitch I would have to call tower and ask they should be able to tell you pretty quick. the tensioner is a 1/8 bolt thru the trans with a piece of pipe one it ( acting like a roller) and I have one of the fancy ones from tower on the other side, and I also got the better belt. I needed up doing the second because I had done the first one with the stock belt on the the new belt is a little longer so I did another tensioner. |
