05-05-2007, 05:07 PM | #1 |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
| Broke dogbone pin on half shaft!
Ok well i can honestly say i have NEVER *knocks on wood* broken a axle half shaft on my tlt... i have never had the ball of the shaft break off, and i ran the same set of shafts for about a year with no probs... untill i dropped a 27 turn motor in to do some trail driving... then i wore out the pins on my half shafts, so i replaced front a rear shafts with new ones, and just today when i was crawling i heard a nice POP... the front driver side dog bone pin finally wore through. I was thinking of cutting a drill bit shank of the right size to put in the hole but i have no clue on how to secure the pin... mabey i could drill a hole directly in the center for a set skrew? and btw.. where can i get thoes axle c's! i need some! Last edited by nd4spdbh; 05-05-2007 at 05:11 PM. |
05-05-2007, 05:20 PM | #2 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Do you still have the center dogbone drive shafts from your TLT kit? If so they press right in.
05-05-2007, 05:20 PM | #3 |
Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
Might try to Silver solder it. Won't stick to a coated drill though. Might try music wire or a shiny uncoated drill bit. |
05-05-2007, 05:48 PM | #4 |
| ooo yes as a matter a fact i have 4 center dog bones... 2 of which have never been used... ill have a go at that... or if i could find a drill bit that fits perfect.... 3/32 bit is too big, and 5/64ths is too small... looks like i need about a 2.2mm drill bit.
05-05-2007, 05:51 PM | #5 |
Since they are pressed in to keep them in place I wouldn't recommend drilling or using pieces of a drill. The pins have little splines on them to keep them in place.
05-05-2007, 05:52 PM | #6 |
are you talking about drivelines from the tranny to the axles? upgrade to pede shafts if so.
05-05-2007, 06:18 PM | #7 | |
the guy above me was saying the pins in the stock center drive shafts are the same. Im thinking if i could find a drill bit thats just a lil to big, i could put the bit in the freezer for awhile, and then heat up the head of the halfshaft and stick the bit through the hole. then everything would cool off and the bit would be stuck in there.... it might just work! | |
05-05-2007, 07:34 PM | #8 |
