05-06-2007, 09:58 PM | #1 |
Newbie Join Date: Feb 2006 Location: Swansea
| Mounting R2 in a k2-3l
is drilling four holes in the chassis plate a little over kill... if so would two holes should be strong enough?
05-06-2007, 10:38 PM | #2 |
i just used two in my j2... 2 should be fine.
05-06-2007, 10:49 PM | #3 |
Pebble Pounder Join Date: Aug 2006 Location: port angeles
two holes will work just fine i drilled 4 and it is great but it only needs 2
05-07-2007, 06:33 AM | #4 |
As said before 2 would work, you may want to use diagnal holes though. Not really 100% needed but would help just a little.
05-07-2007, 12:30 PM | #5 |
I would also like two use the diagnal holes but I want the tranny to be all the way to the edge of the chassis plate so I can leave the drive shafts the same lenght.. or does that really matter?
05-07-2007, 01:28 PM | #6 |
| Doesn't really matter, but when you get into having spares laying around, having parts that can be interchanged front and rear is a good idea. So instead of spare front and rear specific shafts, you'll just need one.
05-07-2007, 01:46 PM | #7 |
Thank you all for your help, Neal
05-07-2007, 10:50 PM | #8 |
I only used 2 holes in my 2.2 TXT, and I grenaded the innards of the tranny, but the 2 bolts held it just fine. |
