05-09-2007, 01:19 AM | #1 |
Newbie Join Date: Mar 2007 Location: Finland
| Bluebeetles first attempt to make a crawler ***Updated body***
Ok guys, after modding my high-lift enough, but still wanting better performance, I decided to give it a go.... Ordered a TLT, tires etc etc.... Picked up some 3mm alu from a friend of mine, and made the chassis plates. Also made the servo/upper link mounts, bulletproof 3mm alu! The upper part, where the shocks are attached, is replaceable and attached to the sideplates with two screws. This way I don't have to remake the whole thing if (when) I mess something up.... Also picked up some Milwaukee V28's from a shop near me, and made some 2S packs, mounted on the steering servo which is quite common I think. Comparison to a normal 7,2V stick-pack The heart of this machine is the motor, a ss5800 5000kv brushless from Novak, which is controlled by a GTB I had lying around. To make it possible to crawl with this puppy, I installed a rc4wd 4:1 GRU, work like a charm and TONS of torque starting really low... GRU shown on my velociti 6,5R, the first motor I planned to use I relocated the lower link/shock attachement to gain some clearance for my steering, just drilled new holes through the axle housing: And this is how she looks atm, with Mad Truck-tires: Feel free to comment, I know I have made some stupidities building it.... Edit: the rockrings are also diy, made out of 2mm stainless to gain some weight.... Edit 2: This is why I call it "XtremePede" : Last edited by bluebeetle; 05-11-2007 at 04:52 AM. Reason: new title |
05-09-2007, 07:28 AM | #2 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
even though you moved the link mounts inward on the axle, I would still recommend using the two outer bolts in the stock location. Other that that, and a high looking COG, it looks good. Also something to think about: you might wanna try and move your body posts to the top of the rig; the side mounts do get you hung up alot more then needed. |
05-09-2007, 08:21 AM | #3 |
Oh yes, the screws are there already... I just took the picture a little too early.... And for the c.o.g, I wanted the chassis as narrow and sleek as possible, so I mounted the tranny like I did. My only competition atm is my friends Pti goliath, and kicking it's butt is all I need.... |
05-09-2007, 08:55 AM | #4 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
Could you go into a little more detail on the V28 system your running? This is the Milwaukee V28 correct? Maybe a view of the battery opened, or how to. How many cells are in there when opened, etc. I'm scared to open my spare up. (Li-po virgin) |
05-09-2007, 09:52 AM | #5 |
No problem, I just run them as 2S-packs, 2 cells in series it means. Each cell is nominal 3,7V just as it is with Li-Pos too. So I have 7,4V when they are serial. When you open the Milwaukee v28, there is 7 cells to play with. Here's a quick picture of a pack (before the shrinkwrap) I made for my friend for his Goliath: |
05-09-2007, 12:21 PM | #6 |
Thanks bluebeetle. Also are you charging these off the Milwaukee charger or another brand? I sell all Milwaukee stuff and was wondering about the v28 if it would work or not. Glad I ran into this thread... |
05-11-2007, 04:51 AM | #7 |
O, just finished the bodyshell for this one.... From now on she will be called "the Rockbug" ..... |
05-11-2007, 06:58 AM | #8 |
Quarry Creeper Join Date: Dec 2006 Location: Finland
That spoiler looks.. you know. |
05-11-2007, 08:16 AM | #9 |
05-11-2007, 08:39 AM | #10 |
Pebble Pounder Join Date: Jan 2007 Location: Gresham
05-11-2007, 08:52 AM | #11 |
Pebble Pounder Join Date: Mar 2007 Location: MOSS LANDING
Nice build I was curious as to how much run time you get with those batteries??
05-11-2007, 12:32 PM | #12 |
Sorry guys, didn't notice that question about the charger at all... But no, I use my Swallow ac/dc, which does have it's own program for Li-Ion. Armrastler: something between 2 and 3 hours it is, enough for me anyway... (I have four of the packs....) |
05-11-2007, 12:59 PM | #13 |
Cool, thanks. I want to try them so bad, but was afraid of nothing I guess.
05-12-2007, 12:06 AM | #14 |
05-12-2007, 01:07 AM | #15 | |
You cut down the LST tires? | |
05-18-2007, 12:20 AM | #16 |
05-18-2007, 12:57 AM | #17 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
wow that 5800 crawls real good with a gear reduction huh no cogging of the motor or stall? |
05-18-2007, 01:45 AM | #18 |
05-19-2007, 11:23 PM | #19 |
Rock Stacker Join Date: May 2007 Location: illinois
looks good
05-20-2007, 01:20 AM | #20 |
Pebble Pounder Join Date: Jul 2005 Location: vandenberg afb
how tall are those tires? also how soft are they? thanks i have always loved the lst tires. they look like they would do great with a cut and shut job. thanks |
