06-30-2007, 05:38 PM | #1 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
| Delrin housings
Anyone try these yet? I have seen a few aluminum ones around but none of the delrin ones. I am talking about the RC4WD ones.
06-30-2007, 06:11 PM | #2 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
Their bloody expensive! ill take donations if someone wants to give me one. |
06-30-2007, 06:23 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
theyr no more than the alu axles. i got a high lift delrin axle but i have yet to use it since i dont have much of my high lift left due to trading. it sure looks cool though, i got the straight rear.
07-01-2007, 03:44 PM | #4 |
Rock Crawler Join Date: May 2007 Location: Norwich
I'll give you an update when they get here. Using in my tuber build. The anticipation is killing me.
07-01-2007, 07:30 PM | #5 |
RCC Addict Join Date: Jul 2004 Location: The other Crawler State
I have thought about going with the Derlin housings for awhile now. My Super truck build I that I just finished has sucked up all the crawler funds lately though. |
07-01-2007, 08:45 PM | #6 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
Still waiting for the "I broke my axle housing" thread. |
07-01-2007, 09:46 PM | #7 |
07-05-2007, 12:53 PM | #8 |
There has been 3 or so people around here using the aluminum ones but I think if I was gonna spend that kind of change I don't want it to hang up on the rocks! I just wanted to know if anyone has done any durability testing on these. I am building a new comp rig SW3 with some of the new Erickson aluminum comp weight beadlocks, Delrin high clearance links, Crawlmaster power and am considering these housing filled with all the goodies from RCP.
07-05-2007, 02:13 PM | #9 | |
spend your money elsewhere- use the stock housings. The only times I have seen damage to the housing is either wear over a LOOOOONG time or the axle shafts busting and popping a hole in the casing (not a casing failure) You should be just fine with beefed up internals. This is all assuming you are using axle c's and good suspension mounts. | |
07-05-2007, 02:29 PM | #10 |
RCC Addict Join Date: Mar 2006 Location: Xxx
Who makes the delrin ones?
07-05-2007, 02:32 PM | #11 |
07-05-2007, 02:51 PM | #12 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| Quote: IMHO they are nothing but trouble | |
07-05-2007, 07:36 PM | #13 |
RCC Addict Join Date: Feb 2007 Location: LRC
Got mine in they are nice,RC4WD did a good job they are beefy exactly where they should be. dont believe they will be breaking no matter what |
07-05-2007, 08:06 PM | #14 |
07-05-2007, 08:08 PM | #15 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
| That doesn't surprise me at all for some reason. |
07-05-2007, 08:10 PM | #16 |
07-05-2007, 08:11 PM | #17 | |
Rock Crawler Join Date: Nov 2005 Location: Okinawa, Japan
07-06-2007, 10:25 AM | #18 |
I don't EVEN have all the parts I need, still waiting to hear back from Dan about the rigs he is trying to sell down at the shop for me.
07-12-2007, 05:40 AM | #19 |
Here is what I've learned so far 1. Bearing races will need to be shimed slightly (the bearings will slide side to side inside the housings. 2. I'm using an aluminum spool with the rc4wd straight axles. When these two are put together you will only have two clip areas on the axle. 3. The housings are taller than the stock ones. So the bolts holes that hold the housing together are spaced farther apart i.e. your shock/lower link mount will not bolt on. Your Junfac axles braces will not fit. Use some L channel aluminum and fab some up. |
07-12-2007, 07:12 AM | #20 | |
