04-02-2005, 07:12 AM | #1 |
Pebble Pounder Join Date: Jul 2004 Location: San Jose, Ca
| is anybody currently producing a top link mount for the tlt-1
Like the title says..is anybody selling these ??
04-02-2005, 09:32 AM | #2 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Hulk is the only one I know of.
04-02-2005, 06:10 PM | #3 |
Quarry Creeper Join Date: Dec 2004
a lot of us run over the servo mounts like this the problem with mass producing these is in the variations of the servo cases. Differen brand servos have different size cases. Yes the size varies only a little but it's enough for the mount not to fit. It would fit fine on some servos and not fit at all on others.... that HULK mount doesn't fit flush/tight on the servo so that would be a good universal mount. |
04-02-2005, 08:00 PM | #4 |
Rock Stacker Join Date: Apr 2005 Location: Hebron
do you have either a closer pic of the mount or even one that is not mounted
04-02-2005, 08:13 PM | #5 |
04-02-2005, 08:53 PM | #6 |
cool now i see how the plate was mounted for the link mount |
04-03-2005, 09:00 AM | #7 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
They are pretty easy to make- all you need is a drill and a dremel (or hacksaw). Go buy some angle aluminum from home depot, and cut it up to fit the servo, like the picture above. Drill holes for 2 servo screws on each side. Or you can buy some flat aluminum at home depot. Bend it in a vice and make one that looks like this: http://www.gerrish.net/PDRM2660.JPG Ryan |
04-03-2005, 09:20 AM | #8 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
I went with a bent up over servo link mount on my TLT. I just used a cheap $18 metal brake and the vise and hammer technic to form them. Then to drill the holes I just placed the stock bumper assembly over the mount and marked the holes with a sharpie. |
04-03-2005, 09:32 AM | #9 |
I joined the Band! Join Date: Nov 2004 Location: Kennewick
im getting one from Hulk! Hey Etype do you like those geolandars |
04-03-2005, 10:26 AM | #10 |
Well the two times I've taken the TLT outside to run it, something would dump on me. First run the ESC got wet, second run the drive shaft popped off the tranny since my lhs was out of the updated set of diff gears for the pede tranny... But before I build up this chassis I had a sad looking tube frame for the TLT. And I got a few runs with that setup outside and the tires seemed to work pretty good in the snow. I need more time before I can say how they do in the dirt and on the rocks though. I use this TLT mainly for racing with our local solid axle MT club. We have a class just for stretched tlt's, its a pro stadium truck scale class :-P Only 5 of us are running trucks in the class, but its a blast and the things don't handle nearly as well as the modded race clods. But this truck is still more then capable offroad as well. I can tell you that the geolanders are not the tire of choice for racing on carpet though. Maybe tonight I'll start a thread for my TLT finally :-p |
