08-13-2007, 06:47 PM | #1 |
Pebble Pounder Join Date: Feb 2007 Location: L-TOWN
| here is my sw2 (pic heavy)
i got my sw2 in today so far it is a sw2 chassis wit a pede trany stampede shafts a mg 995 a 55t tlt axles wit aluminum knuckles maxx shocks locked axles and trans i still need esc reciver radio parts that u might be albe to donate wheel hexs with the pins (only need 2) |
08-13-2007, 06:48 PM | #2 |
my first mod was steering buffy upper first i saw it was just all thread and was already bending next i found my tubeing then i measured how long i had to make it put it in the vice and started to cut here is wat i came out with i shoved it over the all thread and put the rod ends on then re mounted it to the truck and this is wat i came out with |
08-13-2007, 06:48 PM | #3 |
ya and i have green bearing aka better ones i put the motor in it just now |
08-13-2007, 07:01 PM | #4 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
sure looks familiar. |
08-13-2007, 07:17 PM | #5 |
RCC Addict Join Date: Nov 2005 Location: Kansas
looks cool... but someone told me something about a steering angle when I was setting mine up... looks like you might have the same problem. I fixed mine with shorter upper links in the front |
08-13-2007, 07:26 PM | #6 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
| Yeah he can fix his by moving the front uper ball ends on the chassis to the bottom last hole closest to the tranny! |
08-13-2007, 07:31 PM | #7 |
just mounted my reciver |
08-13-2007, 07:37 PM | #8 |
well i did not like how the suspinsion was set up on the out sid of the thing so i re mounted it in the middle of it makes it wider not sure if flex difference but i like it better lol from it being on the out side it bent it in ward so i had to re bend out ward then i just put in side and bolted back up Last edited by L-TOWN CUSTOMS; 08-13-2007 at 08:00 PM. |
08-13-2007, 07:40 PM | #9 |
Rock Crawler Join Date: Apr 2006 Location: Pineville Ky
What size pinion gear is that?
08-13-2007, 07:57 PM | #10 |
stock tlt lol it was the only one i had i am gonna get a new one
08-13-2007, 08:00 PM | #11 |
My truck has about the same setup your running with a 12 tooth pinion and a 87 spur it has plenty of torque but not a lot of wheelspeed |
08-13-2007, 08:01 PM | #12 |
that y they call it crawling not running
08-13-2007, 08:20 PM | #13 |
3rd mod is i fixed the servo so i get better steering as u see it is at quite a bit of an angle so i un bolted it and thought of what one to put it in i decied the second one bak gives me a preety ever angle for the servo so i bolted it up angle fixed looks good huh? |
08-13-2007, 08:54 PM | #14 |
it took 1st in only comp like it was. no torque flex either. heres ya a vid of it before.starts about 5 minutes in with it. Click here to watch cape-fear-river-solo-run hope it performs as well with you man. |
