Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: not sure if its an Axial or a Mutt
Old 12-02-2007, 08:08 AM   #1
Default not sure if its an Axial or a Mutt
as I had stated on another post.. i recieved a scorpion in a trade (my oldest son hated rock crawling) so I built a Fathead tuber for all the cool stuff the Axial has.. Anyways I had alot of left over parts from other TLT kits laying around and an Axial chassis so here you go....
specs:
Axial Chassis w/battery tray
Traxxas front shocks w/Losi springs
Axial rear shocks w/1 Losi, 1 Traxxas spring
TLT axles w/bearings and G-Made wideners. Front axles houses a CVD
Axial wheels(weighted down 8oz. each in front)with Axial rock lizards
Hitec 645mg servo,
Crappy XRS e.s.c. w/55t lathe
1 cut up Betty body..
the red spring is stiffer to help out with the torque twist..
Oh yeah, It's got a stampede trans too. it fits on the skid if you put the links on the inside of the chassis
the flex shot...
limiting chains are there because I glued the shock caps on when my son had the truck and then I could not get them off to put fuel tubing in to limit the down travel... but it works
2000 nimh battery on the front servo..
Its a mutt alright but it does crawl rather well, just need to get some better tires for it...
fathead is offline   Reply With Quote
Old 12-02-2007, 01:28 PM   #2
Those are TLT axles... so that doesn't make it an Axial. Wrong section.
2JSC is offline   Reply With Quote
Old 12-02-2007, 01:46 PM   #3
But it is 90% Axial parts so it is more axial than anything...Kind of a hard one to say where it would belong
01XJ is offline   Reply With Quote
Old 12-02-2007, 04:18 PM   #4
well in the 1:1 world the truck is usually determined by body and/or chassis. but with rc's since there is so many aftermarket bodies and chassis that would be too hard so i usually judge by the axles.
RCMFMaxxMan is offline   Reply With Quote
Old 12-02-2007, 06:44 PM   #5
Sweet FatHead were ya bored this weekend???
k9popo is offline   Reply With Quote
