Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: My Death Metal Garage DCV/pro TLT-based build
Old 07-07-2008, 02:59 PM   #1
Default My Death Metal Garage DCV/pro TLT-based build
I had this tube chassis built for me a couple of months back and finally had a chance to start building it. Still need a few parts to complete it, and I need to find some drive shafts that are longer than the Stampede shafts or shorten the front end a little. They are connecting, but just barely.
The specs so far:
DMG DCV/Pro chassis
R2D tranny
Mamba Maxx ESC
Integy 55t motor
3Racing shocks (t-maxx), all will be semi-droop inner sprung like the front is now)
Mayhem Double Phatty wheels w/Panther Cougar tires (currently on the Axial)
TLT-1 locked axles w/bearings and straight axles in the rear
Axial blue links
Here's where it sits right now, until I get a few more small parts to finish the links and figure out the drive shaft issue.
MrNate is offline   Reply With Quote
Old 07-07-2008, 07:43 PM   #2
Looks pretty sharp. Those DMG's have always looked so nice.
wrightcs77 is offline   Reply With Quote
Old 07-07-2008, 09:41 PM   #3
Good job i like the t-maxx shocks
MAX climber is offline   Reply With Quote
Old 07-14-2008, 08:23 AM   #4
Thanks guys. The only thing holding me up now is getting the link couplers. Backordered from my favorite shop right now...
Old 07-17-2008, 11:27 PM   #5
Nice.
I have a question though, am I the only one that thinks that this chassis lookslike a chassis made for Batman?
Mr Crabs is offline   Reply With Quote
Old 07-22-2008, 07:54 AM   #6
onlyinajeepxj's Avatar
Nice. That chassis looks fast.
onlyinajeepxj is offline   Reply With Quote
Old 07-23-2008, 06:25 PM   #7
Those are nice I also like the fact they give you more than one place to mount the shocks at.
Dragon51 is offline   Reply With Quote
Old 07-29-2008, 11:43 AM   #8
I have one of those sat in the loft. Wish I had more time to build it... Yours might be the insperation i need.
Ryanbored is offline   Reply With Quote
Old 07-31-2008, 09:41 AM   #9
I hope I find some time here soon! Now I've been challenged to actually finish this build.
Old 08-11-2008, 10:00 PM   #10
that looks good where can i get one of those
crawler619 is offline   Reply With Quote
Old 08-14-2008, 12:51 AM   #11
Did you solve that issue ? You can use T-maxx drive shafts or go on with the Stampede ones using a trick. I read it somewhere on this forum and it consists of using two males and a female for each drive shaft. You cut the head of a female and glue it on a male in order to have a longer shaft.
Hope this help
setecastronomy is offline   Reply With Quote
Old 08-14-2008, 02:10 AM   #12
nice. Looks mean. Jerry is top notch. I like those rims. rc4wd is always out of stock though...
ADDICT is offline   Reply With Quote
Old 08-16-2008, 10:06 PM   #13
I ended up just cutting all my links 1/4" shorter and it worked out just fine. Actually have a couple little things left and it will finally be done. Been working on this since early June!
Those wheels are going back on the AX-10 soon and the Mayhem DP wheels will go on this. I actually picked up the RC4WD wheels from RPP Hobby, who seem to have them more often than RC4WD does.
Old 08-18-2008, 06:26 AM   #14
Finally finished getting the front end together. Still need to figure out how to get a little more flex out of this, because it's a little tight for my tastes. Anyway, only other problem so far is I lost one of the panel screws from the side panel. Those buggers are tiny!
