09-03-2007, 05:00 PM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
| TLT/F350 Portal Axles II
Here are the Version II Portal axles. I did a side by side with stock axles. I have not tried these out. Waiting on a chassis for them. They add the extra height. They eliminate some steering throw. They do however work with the Axial Beadlocks. Side by Side Room for the Axial beadlocks. Width. This shot is with the Junfac widners. These add 1" to the width. This shows the width of the Portals. They add 1-1/4". Height Stock set-up. Portal's Steering throw. Here is what hurts when using the Portal's. The steering throw is limited. I did measure and make sure that they were both the same. The Portal's are on the axle in the back. Hope this helps anyone looking at purchasing these. They will make a great addition to my scale truck. |
09-03-2007, 08:10 PM | #2 |
i can see them being useful in scalers but doubt theyll be popular in competition. you cant use them with CVDs, they limit steering, and they look waay too wide.
09-03-2007, 08:14 PM | #3 | |
Tom | |
09-03-2007, 08:18 PM | #4 |
Quarry Creeper Join Date: Jun 2005 Location: quarryville
throw themon just the rear end..
09-03-2007, 10:07 PM | #5 |
Rock Stacker Join Date: Sep 2006 Location: Big Rapids
Not a bad idea to put them just in the back.
09-03-2007, 10:15 PM | #6 |
Only problem with throwing them just on the rear, is they have reduction in the portals, which will make the front end a different gear ratio.
09-03-2007, 11:38 PM | #7 |
Ah that would be a problem. Good catch.
09-03-2007, 11:44 PM | #8 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
Wouldn't the rear wheels turn the opposite of the front if you used portals in back? |
09-04-2007, 01:53 AM | #9 | |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
But also stated was they add reduction, and well im not impressed at all had them on the scaler they are now gone because i drive my scaler not shelve it! Any chance you can take them apart and get some pics of the gears for us! | |
09-04-2007, 06:34 AM | #10 |
09-04-2007, 07:26 AM | #11 |
Insides!! The top gear is what went on my first set. The grooves on the shaft and inside of the gear stripped. That has not been changed much. I was told that the grooves are deaper. However, for my scaler they should have no problem. |
09-04-2007, 12:45 PM | #12 |
thats what went on my set too they dont look like they changed anything at all!? thanks for the pics though! |
