04-15-2005, 10:54 PM | #1 |
Pebble Pounder Join Date: Jul 2004 Location: San Jose, Ca
| has anybody put a top link mount on a tsc-10 chassis??
I am try to do this using HULKS mounts and I am am having major problems with link placement.. and I am having a flex problem... So has anybody done this succesfully?? |
04-16-2005, 02:28 PM | #2 |
RCC Addict Join Date: Nov 2004 Location: Redding, CA
this is because the tsc-10 top links triangulation narrows tward the chassis and not the axel like on a bulu chassis.
04-16-2005, 08:41 PM | #3 |
Quarry Creeper Join Date: Nov 2004 Location: SW Indiana for four more years...
Try sending PWT a PM. The TSC uses the stock axle setup with the triangulation done at the chassis instead of the axle. You could make it work, but you will need to drill new mounting holes in the chassis above the lower link mounts, then use a small spacer (i.e. ball from a ball link) on the inside of the chassis before you mount the link. It will be difficult to determine where the hole needs to be drilled and what length your upper links will need to be, but I bet it can be done. I would clamp both plates together and drill them at the same time so both links will be mounting in the same spot. |
