09-04-2007, 07:06 AM | #1 |
Pebble Pounder Join Date: Jan 2007 Location: Cincinnati OH
| Bent Pinion Shaft
Has anyone every bent the shaft that comes out of the pinion gear......I put in the new RCP ring and pinions, and after looking at the front one after a run i saw that it was bent massivly.........IDK i have never done this with a stock tamiya one, just wanted to know if i was the only one?
09-04-2007, 07:32 AM | #2 | |
Quarry Creeper Join Date: Apr 2006 Location: Pittsburgh
09-04-2007, 09:10 AM | #3 |
| I'd like to know how that happened. Wow! Since I am running these, I can't imagine how you did that.
09-04-2007, 09:20 AM | #4 |
Quarry Creeper Join Date: Feb 2007 Location: Fresno
Some people are just over achievers. |
09-04-2007, 12:09 PM | #5 |
i wasnt even running it hard.....i am using a rc4wd tranny, tlt axles....bm9 brushless....yea IDK how it happened....must be a defect
09-04-2007, 12:49 PM | #6 |
09-04-2007, 02:13 PM | #7 |
09-04-2007, 02:18 PM | #8 |
Rock Stacker Join Date: Feb 2007 Location: Cincinnati
Kyle, I still need to see this thing, wow. Course you know how my R+P situation is at the moment... were you able to get it out of the axle housing to put a stock replacement in for right now?
09-04-2007, 02:19 PM | #9 |
I doubt it was a defect, it wouldn't have installed if it were bent from the start. I bet you fell hard onto the shaft, like a tumble where you hit a rock with the driveline.
09-04-2007, 02:28 PM | #10 | |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
and...... yeah. someone had to do it. | |
09-04-2007, 02:39 PM | #11 |
| That is what I am thinking. A good rolling tumble can generate a lot of speed, and a rock at just the right place could put all of that force right onto the pinion shaft. I had it happen to me once, I couldn't get the pinion out so the case and bearings were trash too.
