04-27-2005, 02:31 PM | #1 |
Rock Crawler Join Date: Dec 2004 Location: www.ORCRC.com
| TLT axles, pede rims - no threads
Well I'm trying to fit some pede front rims on my tlt axles and I can only get about 2 threads of the axle to stick thru the pede rim for the nut to thread onto.... Did I do something wrong????? Or do I have some just really thick rims. I want to buy the longer super blackfoot axles but Tower is all out of stock right now and my LHS does do tamiya stuff.... plus I'm not even sure if that will fix this problem.. Just curious if there is a quick fix. Last edited by 4RnrRick; 04-27-2005 at 02:50 PM. |
04-27-2005, 02:55 PM | #2 |
Quarry Creeper Join Date: Feb 2005 Location: Lake Tapps, Washington
Rick, The nitro rustler rear wheels are thiner at the axle, than thr elect. wheels. I B.. Last edited by I B RACIN; 04-27-2005 at 03:05 PM. |
04-27-2005, 02:55 PM | #3 |
| quick fix |
04-27-2005, 03:04 PM | #4 |
I also found this, Tamiya TG10-(SP-808 Long Axle), and (OP-345 Wide Hex) for the TL-01 Wild Dagger Wheels, (0445720) This came from R/c car action I B.. |
04-27-2005, 03:19 PM | #5 | |
Is that these part numbers? #50808 or #LXGM26 http://www2.towerhobbies.com/cgi-bin...?&I=LXGM26&P=7 #53345 or #LXGF21 http://www2.towerhobbies.com/cgi-bin...21&FVPROFIL=++ Tower is also currently out of stock on those.... | |
04-27-2005, 03:20 PM | #6 | |
04-27-2005, 04:08 PM | #7 |
Rick, yes thats the parts. Do you have elect. stampede wheels or the nitro? |
04-27-2005, 04:23 PM | #8 |
these are the wheels I have..... Traxxas Front Wheel 2.2" Nylon These are FRONT nylon rims for the Traxxas electric Rustler, electric Stampede, and any other Traxxas vehicles which use a hex-style drive washer. These will NOT work on the Nitro Rustler or Nitro Stampede Traxxas # 3675 Tower Hobbies # LXJK63 http://www2.towerhobbies.com/cgi-bin...?&I=LXJK63&P=7 |
04-27-2005, 05:10 PM | #9 |
Newbie Join Date: Apr 2005 Location: Akron
hi, new guy here. I also have the electric stampede wheels and had the same problem. the TG-10 axles worked great for me, and still have thread to spare.
04-27-2005, 05:21 PM | #10 |
Rick, These are the wheels I have on my stampede crawler http://www2.towerhobbies.com/cgi-bin...&I=LXZS52&P=ML The rear nitro wheel will work, it has a thiner mounting aera around the axle, because the nitro rustler uses a thicker hex. Torry Last edited by I B RACIN; 04-27-2005 at 05:25 PM. |
04-27-2005, 05:44 PM | #11 |
Moderator Join Date: Apr 2004 Location: In my head
I had the same problem with RPM rims for the rear of a Nitro Rustler. I used Dremel to get them to work. You may want to try turning the nut around, I did that and the tapered side of the nut will dig itself a hole in the rim letting you tighten it more. Also my RPM rims want to slip on my INET wheel widners when the truck get into a bad bind (on the plus side that keeps me from breaking axles)
04-27-2005, 06:16 PM | #12 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
I drilled mine about 3/16" deep with a 1/2" drill.
04-27-2005, 07:56 PM | #13 |
Moderator Join Date: Jan 2004 Location: chicago
i got both the front and rear electric rustler wheels. besides the fronts being a much wider offset, they also have a thicker section of plastic which doesnt leave alot of thread. the rear rims have a little recessed area in them that the wheel nut countersinks into and you got plenty of threads, although you get a less wider rig by using them. |
04-28-2005, 08:16 AM | #14 |
Thanks for the helps guys..... Last night I just used the dremel to remove about 1/8" to 3/16" of the material around the center hub. that looked to work pretty good. I also have the rear version of my rims but they have so much backspacing that the inner bead on the rim hits the steer arm.... |
