Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Txt-1 and Juggernaut
Thread: txt-1 rod ends suck! what do i upgrade with?
Old 07-14-2004, 07:14 PM   #1
The Wheels Keep Turning
kevinlongisland's Avatar
Default txt-1 rod ends suck! what do i upgrade with?
i know the txt rod ends for the 4 link pull out real easy and are weak. what do i upgrade them with? thanks in advance.
kevinlongisland is offline   Reply With Quote
Old 07-14-2004, 07:34 PM   #2
Default Re: txt-1 rod ends suck! what do i upgrade with?
Kyosho 6.8 ball ends work great.
these http://www2.towerhobbies.com/cgi-bin...LXT404&P=7
http://www2.towerhobbies.com/cgi-bin...LXT409&P=7
works wonders.
Mud_Flinger is offline   Reply With Quote
Old 07-14-2004, 07:39 PM   #3
06 Super National Champ
JasonInAugusta's Avatar
you can also use some of these....
That's right, franged pillow balls.
JasonInAugusta is offline   Reply With Quote
Old 07-14-2004, 10:40 PM   #4
did you use threadlock? just curious. I didn't at first and had the same problem, then locked them and been good so far.
rckjeep is online now   Reply With Quote
Old 07-15-2004, 12:12 AM   #5
thanks guys.
Old 07-21-2004, 10:04 PM   #6
alright. i got the 6.8mm rod ends and the "franged" (lol) balls. but what a pain in the ass! you have to replace all at once (at least on each axle) because they are a different length and you have to replace all the balls including the hardware.
is there an easier way? anyway i can use the stock ball ends and make the stronger? maybe crazy glue them in? or epoxy them in? i'm open to ideas. thanks guys.
Old 07-24-2004, 12:03 PM   #7
Using the Kyosho ends do you need to make new links or will the stock links work? I mean will the threaded rod from the stock ends go into the Kyoshop parts?
Old 07-24-2004, 02:09 PM   #8
The stock links will work, however they make the links slighty longer and the stock driveshaft won't reach. To work around this, I didn't use the black plastic spacers on the lower links and I cut about 1/8" off the kyosho rod ends for the top links. Or, you could convert to the Traxxas sliders...
schlabinski is offline   Reply With Quote
