07-06-2005, 06:48 PM | #1 |
Quarry Creeper Join Date: May 2005 Location: Crossville,TN
| Axle mounted servo bracket
Several members have asked for a drawing of a plate for mounting servos to the TXT-1 axle. So, this afternoon I made a drawing of my bracket and decided to post it and a couple of pictures of my bracket for others to use or critique or just ignore. Need to reduce the size of the other picts before they will upload. More later... I uploaded a new version as there were a couple of mistakes in the previous one. Last edited by quickster47; 07-07-2005 at 08:21 AM. |
07-06-2005, 07:17 PM | #2 |
| The actual bracket
Okay, here are two pictures of the actual bracket.
07-06-2005, 07:19 PM | #3 |
Quarry Creeper Join Date: Jun 2005 Location: NOrthern Cali
Are you selling them or just giving out ideas?What tools did you use to make them?And how thick of alluminum
07-06-2005, 07:47 PM | #4 | |
| Just providing information Quote:
The aluminum in this particular bracket is .062". I used my bandsaw, mill, drill press, nibbler, several different files and lots of patience and elbow grease. During one Saturday I was able to make four different brackets after I got my technique down and knew what I was doing, which is still questionable. | |
07-07-2005, 08:12 AM | #5 |
Newbie Join Date: Jul 2005 Location: Australia
You could get away with using your marking out gear, a hacksaw, drill and some files!
07-07-2005, 11:43 AM | #6 | |
Newbie Join Date: Sep 2004
I figure a dremmel would have saved me about 2-3 hours though. | |
07-07-2005, 12:00 PM | #7 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
07-07-2005, 01:05 PM | #8 |
"Nice soft Aluminium" doesn't have to mean it's flexible, maybe it's thick enough not to flex? How thick is the top of the case of an old hard drive anyway? |
07-07-2005, 01:14 PM | #9 | ||
I can get a sheet of aluminum (7071 maybe) for $6 which is very strong and works great for the steering servo mounts. | ||
07-07-2005, 01:58 PM | #10 |
"Soft Aluminum" - soft in comparison to working steel with a file/hacksaw combo. It is plenty thick enough not to flex at all |
07-11-2005, 10:44 PM | #11 |
Pebble Pounder Join Date: May 2005 Location: Oregon City, Or
Sweet! Thanks for this thread, quickster. |
07-12-2005, 01:40 PM | #12 |
Newbie Join Date: May 2005 Location: Charleston
I used 1/16" carbon fiber for the servo mounts and it works great. I purchased a 3" X 12" piece for $13.97. It's very easy to cut and shape with a rotary tool and a file. It's a little more expensive than the aluminum but I think the ease of use and the overall coolness of it outweigh the cost difference. Go here -> http://www.mcmaster.com/ |
07-12-2005, 01:55 PM | #13 |
| Carbon Fiber
I have just acquired some of the 1/16" carbon fiber material and will be making myself another set of the brackets. The only caution to using CF material is to make sure you use some sort of breathing protection when working with the stuff as it can be deadly to the lungs, and then of course, yourself. Last edited by quickster47; 07-12-2005 at 01:56 PM. Reason: English |
07-19-2005, 11:45 AM | #14 |
Quarry Creeper Join Date: Jan 2005 Location: Milan, Italy
That's exactly what I need (well one of the things ) for the reborn of my shafty. Thanks a lot. ;) |
07-30-2005, 05:58 PM | #15 |
Rock Stacker Join Date: Jul 2005 Location: richmond
| how
how did you cut it out and how did you come up with the exact outline for the mount?
08-10-2005, 12:19 PM | #16 | |
RCC Addict Join Date: Nov 2004 Location: Redding, CA
Anyone know were I could get a couple sets? Last edited by mike; 08-10-2005 at 02:31 PM. | |
08-16-2005, 03:50 PM | #17 | |
| I Used Quote:
I then started out with two squares of aluminum and drilled all the holes. Next step was to use a band saw and then an aluminum nibbler tool to do some of the final inside fitting. It then took me a half hour or so of filing to get a good tight fit. | |
08-16-2005, 03:53 PM | #18 | |
| Servo post mounts Quote:
