Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Locker for TXT
Old 08-06-2008, 03:05 PM   #1
Default Locker for TXT
Options
what you guys got?
I know of the RC4WD ... are they good, do they hold up?
I have smoked the stock R&P with JB Weld .... and even tried the gear placement trick... still keeps coming unlocked
Thanks
Jeepernick is offline   Reply With Quote
Old 08-07-2008, 12:52 AM   #2
or
http://www.rcalloys.com/pricelist/txtspool.html
or 4:1 with hardened steel spool
or if you like the stock 2:1 axle ratio
remove the inner bevel gears
drill out the lower gear and diff cup to 8mm
glue the spool in with Loctite 648
EGRESSor is offline   Reply With Quote
Old 08-07-2008, 08:40 AM   #3
I have the CVDs for it
I would like more info on the 4:1 setup
do you have a parts list?
Thanks
