Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: 4:1 Case mods
Old 02-28-2009, 05:23 PM   #1
Default 4:1 Case mods
Well im in the works of installing my 4:1's.. The top half of the axle housing was easy. It was when I got to the bottom half I ran into problems.
After grinding in the bottom half, it was paper thin on the bottom, so thin I pushed it through LOL
I was wondering if anyone out there made a "pumpkin cover" for the bottom of the TXT axles.
I already have the bottom of a aluminum can fabbed up to epoxy on. I just think it will not last very long, and it will give way and hit the ring gear..
My ring gear is pretty exposed now after I cut out the paper thin area some what cleanly.. LOL
Any ideas ?
Thanks
hessian18 is offline   Reply With Quote
Old 02-28-2009, 10:22 PM   #2
I've been putting mine off for the same reason. I'm thinking about brazing up a steel cover, and I'll do a write up on it if I do.
chrisjlittle is offline   Reply With Quote
Old 03-29-2009, 05:41 PM   #3
I came up with something if anyone's interested. The spools I got were drilled and tapped for revo spur gears, so I picked up some RRP 40t spurs. Yes, you can only get them with the clutchbell, but I have a revo so it's not a huge loss. I imagine you could sell the clutchbells on e-bay and recoup some of the cost. Anyways, these gears are signifigantly thinner than the ones that come with the 4:1 kit, and the teeth are a little shorter (the pitch is the same and the pattern is still good) so you only have to cut the little braces out of the bottom half of the case and you don't have to get into the bottom at all. Plus RRP steel spurs are practically indestructable
Old 03-29-2009, 07:49 PM   #4
I was just talking about this today...
I will have to look into doing that, even though i have a "sight hole" in my lower axle case now ahahahaa
Im still looking into a way to make a axle housing skid plate... I got some ideas I just need to try out..
Old 03-30-2009, 12:10 AM   #5
Super TXT...
EGRESSor is offline   Reply With Quote
Old 03-30-2009, 12:18 AM   #6
I made some of those up from soda cans...
They just dont seem strong enough to last, they would just get pushed into the gear after some hard hits....
Im thinking of taking a spray can bottom and cutting/welding it to fit, then epoxy it to the housing..
Old 03-30-2009, 12:33 AM   #7
i use two of them per axle , glued with glasfilled epoxy
works good
Old 03-30-2009, 02:09 AM   #8
REST IN ALOHA CHIP
YoUnG_vErSiOn's Avatar
i used this on mine:
structurally sound and slippery once dry. dries within 5 minutes with a 2 hour cure time.
i also use this for styrene fab as well(FYI).
YoUnG_vErSiOn is offline   Reply With Quote
Old 03-30-2009, 08:44 PM   #9
Cool more options are always nice...
Thanks guys for your input
Old 06-18-2009, 10:38 PM   #10
A new to the site and wanted to find out where can you pick up a 4.1 kit for these axels
808mills is offline   Reply With Quote
Old 06-18-2009, 11:43 PM   #11
http://www.rccrawler.com/forum/showthread.php?t=183476
Old 06-19-2009, 07:27 AM   #12
Originally Posted by EGRESSor View Post
I cant wait for mine to get here!!!
JeremyH is offline   Reply With Quote
Old 06-20-2009, 10:15 AM   #13
Say in the gallery theres a pic of a txt with a metal cover on the bottom of the pumpkin a remember seeing it cause it looked sweet ill try and find it later if i get time.
Bubba73 is offline   Reply With Quote
Old 06-20-2009, 10:18 AM   #14
You mean this one:
Old 07-24-2009, 02:54 AM   #15
that is just hilarious! yeah if you get time... it was posted a few posts up. Ha! that just goes to show, no one reads previous posts. lol pretty cool trick though, using the bottom of soda cans for a skid plate. that beats my idea of using cans to make crush cars. lol
edwalsh18 is offline   Reply With Quote
