Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: BEST IDEA EVER!!!!LOOK HERE!!!!
Old 10-19-2004, 06:14 PM   #1
Default BEST IDEA EVER!!!!LOOK HERE!!!!
I noticed some of u guys screwing around with the batt in the front, cant you just change the wiring on the motors, put the servo in the rear and your set? will this work or has someone tried and it doesnt? i would try it right now but my trucks aprart to lock the diffs! so let me know asap!!!! or just rotate to tranny 180 and put servo in back? but just change wires ( evern easyer right???)
so let me know if this will work with moving servo and fliping wires!!
thanks!
airranger is offline   Reply With Quote
Old 10-19-2004, 06:34 PM   #2
Location: orange county n.y. , building the hydro crawler
Default Re: BEST IDEA EVER!!!!LOOK HERE!!!!
can you exlain more its rather confusing :?
sambmx is offline   Reply With Quote
Old 10-19-2004, 06:37 PM   #3
thanks!
thats what every is doing
bigred is offline   Reply With Quote
Old 10-19-2004, 07:33 PM   #4
Diggin' the new SCX10 II!
badger's Avatar
You are better off not reversing the wires on the motor if the motor has advanced timing. This will cause the motor to draw more amps which will generate more heat and decrease your run times.
If you have a motor with 0 degrees of timing then you can reverse the motors without any negative affect.
If you install a mammoth gear reduction then you can put your battery in the front and your motor in the rear and you can leave your motor wired normally. The Mammoth gear reduction will reverse the rotation for you. This is the way my setup is.
badger is offline   Reply With Quote
Old 10-19-2004, 08:51 PM   #5
MODERATOR™
EeePee's Avatar
Like Badger said, the timing won't be right, and cause undo heat.
So, I bought a reverse Mag Meyhem motor and really just drove the truck backwards.
Well, until I got a GD-600 gear reduction. Then I went back to a 540 motor.
Well, until I mounted my batteries elsewhere...hehe. Which I'll post about...
Sounds like you're still using the 3 step mechanical speed control?
EeePee is offline   Reply With Quote
Old 10-19-2004, 10:44 PM   #6
OK - Badger I gots a bone to pick with you. - remember the "mammoth gearbox Q's" post of mine? - well I finally figured out why I wasnt understanding you --
badger wrote:
No the mammoth does not reverse anything which is nice when if you need to run a motor with adv. timing.
Just get a normal rotation motor.
But now you say --
So which one is it?
_________________
jeep_boy02 is offline   Reply With Quote
Old 10-19-2004, 11:20 PM   #7
badger's Avatar
But now you say --
So which one is it?
_________________
Sorry Jeep_boy02, you are absolutly correct. I was incorrect in the thread "mammoth gearbox Q's" and Kona_joe corrected me later on in the posts. I forgot to go back and change my post so this does not happen.
I did change my post in the other thread to reflect the correct info in this thread.
Bottom line is: the Mammoth does reverse the rotation so depending on where you mount your motor in the chassis (front or back) you will want to buy a reverse rotation (front) or a normal rotation (rear) motor.
Sorry about the confusion.
