Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: New user from Italy need little help :-)
Old 10-29-2004, 08:57 AM   #1
Default New user from Italy need little help :-)
My name is Fabrizio and I'm an italian new user, in my country the rockcrawling is not developed, the costs are high (in Italy the txt1 cost about 650$) and every parts are impossible to find but now I've see yours forum and for me is simply the best rc crawler site on the web!
My crawler adventure is started in december when is arrived the TLT1 (can you see it at http://album.foto.virgilio.it/killernow/590663) but now I've found my love: TXT1... I've read same post before start my mods and many thanks for the idea (kona-joe, Dirk, rckjeep...), this is my actually (unfinished) set-up: cutted chassis and trasmission relocated, locked diff, progressive ecd shocks, custom estended links, custom steering links, rear servo plate (not definitive), chassis skid (another is ready to bolt), lexan battery plate, esc plate, pro-line body and jugger wheels; for the electronics: esc lrp truck digital, hitec pro-car radio, servos: front Hitec 1/4, post.Hitec hs5945mg (all without servo saver), Graupner speed 600 motor with Graupner 2.8:1 reduction, 11.1V Li-Po 2000mAh for motor and 6V kan 1050mAh for servos. W/b is about 15.75-16.5" and center clerance is 4-5.25". Old photo http://album.foto.virgilio.it/krawlernow/821507/
Next addiction: e-maxx tranny, revo shaft (grrrr only one is arrived...), alu spool, alu hubs and decent rims-tires.
The truck work well and compare to stock is another planet, stable and have great torque (speed is about 4mph) I want only more clerance in the axles and lower c.g.with emaxx trasmission...
And now........................ THE QUESTIONS hehehe:
For the wheels I've think this 2 combo and I need Yours opinion:
a) Maximizer beadlock w/off-set (only the alu units have off-set? I like the plastic one but I'm not sure if they have off-set...) + TTR emaxx wheel adaptor or rc inet + bft tires (these tires can fit on maximizer rims without any modification? I think yes but not sure).
b) Rpm stablemaxx rims + TTR emaxx wheel adaptor or rc inet + narrowed Jumbo kong... The kongs are a big problem for the txt axle? (in my 1:1 Jeep TJ with stupid bf mud 32" I've broke ring/pinion and shaft... suck dana!!!)
What e/t-maxx rims have the the high off-set?
For now is all...
PS sorry for the language but is best I can :-)
killernow is offline   Reply With Quote
Old 10-29-2004, 10:03 AM   #2
Default Re: New user from Italy need little help :-)
Here are the beadlocks with the good offset http://www.maximizerproducts.com/x.html
as for adapters i run the TTR ones on my clod and have had no problems yet but...if money is not an issue i would go with the inetrc alum ones with the widner they make..
TerribleOne is offline   Reply With Quote
Old 10-29-2004, 10:06 AM   #3
"PS sorry for the language but is best I can "
Are you kidding me?!?!?! You write better than half of the meat heads on this forum!!
Good luck with your project!
What part of Italy are you from?
DirkDigler is offline   Reply With Quote
Old 11-16-2004, 11:05 AM   #4
ciao sono giulio e anch'io sono italiano abito vicino varese.
Anche a me piacciono un sacco sti truck che si arrampicano sulla roccia ma fino ad ora non ne sapevo niente.
Sto cercando di acquistarne su questo sit0 uno ma sono tutti diversi e ci capisco poco ad esempio il fatto che possono avere 4 ruote sterzanti con un motore per ogni differenziale!
altri con due ammortizzatori altri con quattro.....
Boooooooo fammi sapere tu se sai pił di me e quanto possono valere usati sti cosi. ciao
ilguru is offline   Reply With Quote
Old 11-16-2004, 11:06 AM   #5
Old 11-16-2004, 11:07 AM   #6
Diggin' the new SCX10 II!
badger's Avatar
Translation please!
badger is offline   Reply With Quote
Old 11-16-2004, 11:10 AM   #7
go to www.towerhobbies.com. i think they ship international and they are very inexpensive.
fastmaxxcooper is offline   Reply With Quote
Old 11-17-2004, 02:38 AM   #8
This is the first italian forum on monster truck & co http://www.essevoloteam.it/
Shop? tower-sheldon-stormerhobbies.... only USA
Old 11-17-2004, 09:57 AM   #9
Here is what was said.
hello they are giulio and anch' I am Italian near dress Varese. Also
to me piacciono a bag sti truck that they scramble up on the cliff but
till now not of I knew nothing. I am trying to acquire some on this
sit0 but they are all various ones and I understand the fact little as
an example to us that can have 4 wheels steering with a motor for
every differentiates them! others with two shocks-absorber others with
four..... Boooooooo makes to know me
No, it's not perfect, but at least it can be read now
Jam1sstang is offline   Reply With Quote
Old 11-17-2004, 10:04 AM   #10
Great Jam1sstang yours traslation work well
Old 11-17-2004, 12:22 PM   #11
Powered by Awesome
TwistedXT's Avatar
I was looking around your photo albums and i must say, that is some nice work you have done there... Keep it up and i know i speak for other here when i say that we would love to keep seeing more of your customer works.
wait a minute... if its noon here (denver colorado) then does that mean that its like 1am or so there?
This proves it.... people all around the world know that Shafties are the way to go....
TwistedXT is offline   Reply With Quote
Old 11-17-2004, 04:10 PM   #12
AFJ
did you use systran?? tried that but its not perfect but it gives an idea
AFJ is offline   Reply With Quote
Old 11-18-2004, 07:22 AM   #13
TwistedXT I need only the time of this week end... many mods are on the way, new radio plate, servo relocated, motor+servo battery relocated (the first between trasmission and skid), front body bumper....... and I need new shocks because the progressive ecd are shith for me
