Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: steering help
Old 09-29-2010, 07:11 PM   #1
Default steering help
i finally got my txt-1 running but i noticed that with a standard servo it wont turn left or right all the way should i go with dual servos or what?
Thanks,
Boneskid1
boneskid1 is offline   Reply With Quote
Old 09-30-2010, 10:42 AM   #2
Thanks,
Boneskid1
Standard servo is a little weak.
I'm using a Hitec 625MG servo. It does turn all the way left and right (on 2.2's) but not all that quickly. I'm generally satisfied with this servo over a standard Futaba S3003.
ARC MotorSports is offline   Reply With Quote
Old 09-30-2010, 11:06 AM   #3
ok will the traxxas 2075 servo work?
Old 10-07-2010, 12:35 AM   #4
I would look for a servo with a bit more tourqe then the traxxas 1, use a servo with @ least 15kg of torque or more
Cortina79 is offline   Reply With Quote
Old 10-07-2010, 08:03 PM   #5
I have a HiTec 5955 on the front of mine, it works OK, until you have a wheel bound up, then it wont turn it either. If you have the diffs locked, you are fighting all 4 wheels when you turn, with no differential action, the tires will have to scrub.
redbeard is offline   Reply With Quote
Old 10-11-2010, 05:34 PM   #6
ok now i got a servo but before it got here i drove my truck and i have been haveing very terriable chassis twist when i go in reverse or forwards what do i change i think i have a 13 or 14 tooth pinion and a 55t lathe motor i also dont have the little arm like things that went on the bottom suspension links what do i change or mod to fix this
Thanks,
Boneskid1
Old 10-12-2010, 05:52 PM   #7
Chassis twist is completely normal- stiffer springs and/ or a different suspension setup may help. What are you doing with the truck exactly- planning on modding it into a crawler or just general bashing around? The 'arm-like things' are sway bars to reduce the tendency for the inner wheel to lift when turning.
Have some inspiration for mods...
http://www.robotwars.00server.com/txtproject.html
http://robotwars.00server.com/projectmulligan.html
thats if bashing is your thing, otherwise you have alot of reading to do on the subject of crawling- lots of threads with great info ( they wont read themselves )...
suicideneil is offline   Reply With Quote
Old 10-12-2010, 06:55 PM   #8
well kinda of multiple things i need to get rid of the tourqe twist now cause its bad and i know it will always be there but i will be doing lite crawling and mostly trail driving/crawling
i heard something about moving your upper links to accommodate for this but cannot find any pics to see what they mean by moving the links up
Old 10-27-2010, 05:15 PM   #9
kick
