Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Axle Gear Ratio
Old 11-23-2010, 05:13 PM   #1
Default Axle Gear Ratio
Im in the middle of a project and I was wondering if someone knows the correct gear ratio for the TXT-1 axle alone. I tried to compute for it and I get 2.1 : 1 but not sure if that is correct. I tried to search the forum which mostly hits only for tranny gear ratio. This make it even more confusing cause now I'm not sure how the 34 : 1 ratio will be achieve if the axle gear ratio I've computed is 2.1 : 1. Hope someone can shed some light
Thanks
TruckBasher is offline   Reply With Quote
Old 11-23-2010, 11:49 PM   #2
Thanks
The Axles are indeed 2:1 that is an easy one to figure out I have heard that the final reduction with 15t pinions is 34:1
CraZySteve is offline   Reply With Quote
Old 11-24-2010, 05:48 AM   #3
Thanks for confirming this....2 project in the process of completing and this info will help a lot...
Old 12-03-2010, 08:05 AM   #4
Ya, the axle ratio is 2:1, the trans is 17:1 with 15 t pinions..
PEDEcrawlerguy is offline   Reply With Quote
Old 12-04-2010, 08:55 AM   #5
Egressor used to sell a 4:1 conversion for the diffs......I've got two sitting on my shelf in the garage!
JeremyH is offline   Reply With Quote
Old 12-04-2010, 12:52 PM   #6
Jeremy,
You have a PM
-CS-
Old 02-26-2011, 10:09 AM   #7
Yeah, you're right, axle gear ratio is 1:2,1 not 1:2,0
Check it: Gear ratio of the txt axle?
krzysiek-gdansk is offline   Reply With Quote
Old 04-10-2011, 10:00 PM   #8
What did the reduction used to go for? I found the gears in 303 stainless with hub for $17 each for the 40t and $15 for the 12t pinion also in stainless. Both are module 1 metric gears. If someone could preceisely measure the diameter of their gears to confirm these are correct, I will post links.
Nate
sig_p232 is offline   Reply With Quote
Old 04-11-2011, 09:08 AM   #9
Nate
I think I paid $65 for mine
Gula is offline   Reply With Quote
Old 04-11-2011, 11:13 AM   #10
Nate
So the 40T w/Hub is meant to drive TXT-1 inner axles shafts?
If so what is your source - I would LOVE to get some!
Also the diameter should be the same as others - if it is a 40t Mod 1 gear then the 40t and the Mod 1 gear specification will ensure the diameters are the same.
