06-04-2006, 06:11 PM | #1 |
RCC Addict Join Date: Jun 2004 Location: Bruiser Heaven!!!!
| jugg2 trail truck
Hey everyone, since i have the week off work. I started to make a frame for the jugg and tryed to make it as scale as much as i can. There is still work to do on it, like the 4 link, steering, e-maxx tranny mount and more. here are some pics of what i did today. And if the mods. think this is scale then please move for me and thank u for all the info. on here. And i need help on want tire to use, the all-t's or the swamp dawgs and that is the last pic. rich |
06-04-2006, 06:35 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Holiday, FL
Nice To See Ya Back. I Think You Should Run The All-t's The Swamp Dogs Look Small On It. What Axles Are You Going To Run
06-04-2006, 07:11 PM | #3 | |
Pebble Pounder Join Date: Mar 2006 Location: igloo, Alaska
06-04-2006, 07:23 PM | #4 |
thanks for the comps. going to do some work on monday. and i forgot to give the specs. for the rig and yes i'm using jugg axles too. and the body is a pro-line ford f-150 for a MGT or LST so this going to be a big trial truck here are spec.s: wheelbase-13.75 width-12.5 |
06-04-2006, 08:48 PM | #5 |
Newbie Join Date: Mar 2006 Location: america
i'll trade ya the tlt for it when you're done |
06-04-2006, 08:56 PM | #6 |
Quarry Creeper Join Date: May 2004 Location: Hartford, Connecticut
Cool looking start! Frame/cage/bumpers look as if they fit the body very well. I would reccomend using the All-Ts. You will probably find the extra diff clearance they give to be crucial in the performance department. Normal 2.2s and Jugg/TXT/Clod size axles will bang the diff cases on even the smallest rocks.
06-05-2006, 09:07 AM | #7 |
Quarry Creeper Join Date: Jul 2004 Location: Deland
nice build, I would use the All Ts streched around a set of narrowed clod rims.
06-05-2006, 11:55 AM | #8 |
Pebble Pounder Join Date: Sep 2005 Location: College Station
very cool!!! how wide is your chassis? can you show pics of you axles also?
06-05-2006, 12:26 PM | #9 | |
I GUESS I SHOULD HAVE READ IT MORE CAREFULL THANKS FOR POINTING IT OUT FOR ME | |
06-05-2006, 01:49 PM | #10 |
thank u for the comps. and yes i'll post some pics of the truck with the axles under some time tonight. rich |
06-05-2006, 05:58 PM | #11 |
did some more work on the truck today i'm done for now till the parts come in about a week from now. here are some pics of what did. the tranny is mounted and the shock mounts are done. now for the pics. rich |
06-05-2006, 09:10 PM | #12 |
Rock Crawler Join Date: Jan 2006 Location: Dallas
Nice! looks realy good,nice tube work too! cant wait to see this all painted and done.
06-05-2006, 09:18 PM | #13 |
got bored and cut up some clod rims to mount the all-t's too and flatfender they work great and they only put a 1/4" to the over all width of tires mounted to the axles. and i think i may use the 2.2 red rock tire becuase the look more aggresove then the all-t's do and here are some pics too. from left to right; stock clod rim, 2.2 stampede rear rim and the hevaly mod clod rim and a pic of the all-t's mounted to the mod clod rim Last edited by rocpede; 06-05-2006 at 09:21 PM. |
06-07-2006, 10:52 AM | #14 |
Rock Crawler Join Date: Sep 2005 Location: IDK
Can you please try the mashers on the modded clod rim cause i cant get 2.2 all't for my txt 2.2 rig but i can get masher 2k's Can u post them up pelase or send them to my mail: misa_di_brijn@hotmail.com greets and thanks nice looking truck allready btw What color do u have in mind for the body>? |
06-07-2006, 11:54 AM | #15 |
the mashers are mounted on the 2.2 rims for my stampede and they will fit just the same way the all-t's do on the clod rim and for color it my me red or black. rich |
06-07-2006, 11:28 PM | #16 |
thanx rocpede i really appriciate it could this be done with txt wheels also or not |
06-08-2006, 12:41 AM | #17 | |
06-08-2006, 01:01 AM | #18 |
yes indeed they are i just measered them but it does have an other things attacht to them a sort of paddles. should i shave them from the rim? what sort of glue are you using to stick the 2 halfs together? thanx y'all realy helped |
06-08-2006, 06:50 AM | #19 |
the glue that i'm using on the rims is thin CA glue and dries in about ten minutes. i have never own a txt so i don't no what u are talking about with the sort paddles, on the rim. rich |
06-08-2006, 09:53 AM | #20 |
I have narrowed a set of Jugg rims for 2.2s and yes you do have to remove the "paddles".
