Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Parts for my txt-1
Old 12-13-2004, 04:34 PM   #1
Anonymous
Guest
Posts: n/a
Default Parts for my txt-1
What do you guys think about me buying an novak evx two magnetic mayhem motors and two 9 tooth pinion from robinson racing.
Old 12-13-2004, 04:38 PM   #2
Default Re: Parts for my txt-1
Or instead or 2 motors just buy one and a gear reduction. Cheaper and alot more power. Just my opinion though.
mx721suzuki is offline   Reply With Quote
Old 12-13-2004, 04:39 PM   #3
Anonymous
Guest
Posts: n/a
thanks i was thinkin of getting the gd 600 but i dont know how it goes on.
Old 12-13-2004, 04:44 PM   #4
Diggin' the new SCX10 II!
badger's Avatar
That is great for bashing but not really needed for crawling. Get a gear reduction and either a lathe motor or a magnetic mayhem and a Super Rooster ESC.
badger is offline   Reply With Quote
Old 12-13-2004, 04:50 PM   #5
Anonymous
Guest
Posts: n/a
How about 9 tooth pinion gd 600 rooster not super and magnetic mayhem
Old 12-13-2004, 05:00 PM   #6
badger's Avatar
9t pinion and a gd600 with a mag mayhem will probably net you almost no wheel speed. You might need to bump up the pinion.
The rooster with be fine with that as well, but you will need an rx pack for your servo/s.
Old 12-13-2004, 05:09 PM   #7
Anonymous
Guest
Posts: n/a
Thanks, what would be a good # tooth pinon to use on the motor? sorry, im new, and how do i mount the gd 600 to the tranny? and what tooth pinon should i use on the output shaft of the reducer? i also read that you need to file down the out put shaft to get the pinon to fit is that true Thanks A lot Badger
Old 12-13-2004, 05:12 PM   #8
badger's Avatar
OK, now you need to sit back and read some more. The answers to your questions are all here in other threads. Try searching a bit for some of your questions.
Old 12-13-2004, 05:21 PM   #9
Anonymous
Guest
Posts: n/a
i knew you were going to make me search lol sorry if i put a lot on you
Old 12-13-2004, 05:27 PM   #10
A good size pinion for this would be a 15 tooth and the output size you should run is the 3.8 with a m.m you should be around 130 to 1 final
1beatjeep is offline   Reply With Quote
Old 12-13-2004, 05:29 PM   #11
Anonymous
Guest
Posts: n/a
can you explain 3.8
Old 12-13-2004, 06:02 PM   #12
CSR
I run a little higher gearing than a lot of folks, I like being able to get the tires spinning if I need momentum to hop up a ledge or rock. I'm running a Mag Mayhem on a GD600 with a 15T on the output. I have the torque to go slow but can pin the throttle and really spin the tires if the need arises.
CSR is offline   Reply With Quote
Old 12-13-2004, 06:11 PM   #13
Anonymous
Guest
Posts: n/a
Its final im getting a super rosster two mag. mayhems with 9 tooth pinons
gears ill deal with a gd 600 later What do you think
Old 12-13-2004, 06:19 PM   #14
badger's Avatar
I guess you did not understand the first time. You DO NOT need 2 motors when using a GEAR REDUCTION. You will not be able to bolt the second motor to a gd600 so it will be a waste of money to buy 2 motors.
This thread really should be in the newbie section now.
