08-04-2004, 11:58 AM | #1 |
Quarry Creeper Join Date: May 2004 Location: Neosho
| suspension travel
would getting droop along with compression be as simple as putting longer shocks on with softer springs so that it is half way compressed from the vehicle weight?
08-04-2004, 12:09 PM | #2 |
| Re: suspension travel
If you do that, the suspension will tend to unload while driving and allow the chassis to flop around more. A better way to get droop is to run a limiting strap at the center of the axle to the chassis. The strap will preload the suspension and allow for droop under articulation. Look at the 1:1 buggies running coilover shocks, almost all of them run limiting straps at the center of the axle. I have seen them used by many r/c crawlers on the boards and have just recently put them on mine. It seems to work well on Adman's Mach1 over in the Australian comps. Just my thought. |
08-04-2004, 12:41 PM | #3 |
Quarry Creeper Join Date: May 2004 Location: portland OR
yea, i had the stupid idea of using tmaxx springs on savage shocks with out a limiting strap. the txt wave. lol. but running a limiting strap in the center of the axle is perfect. jorDANK |
08-04-2004, 04:51 PM | #4 |
Rock Crawler Join Date: Jan 2004 Location: Santa Cruz, CA
you can alway use the old trick of puting fuel tubing inside the shock that way the shock shaft cant fully extend. |
08-04-2004, 08:26 PM | #5 |
Pebble Pounder Join Date: Apr 2004 Location: Wollongong - Australia
You'll probably have to go with fairly firm springs too. I tried this type of setup and it was quite floppy so it didn't last long. The main problem I found was with the wheelbase decreasing as the wheel drooped following the arc of the lower link making it pretty tippy at times. I think triangulating your lower links helps keep the axle straighter though. I didn't play around with it much but I'm sure with a bit of trial and error engineering you can get it to work pretty good.
08-04-2004, 09:42 PM | #6 |
Thanks for the info guy - I already gots the triangulation done and think I know of somewhere to start with the limiting straps. But how long should they be? where ever I want my ride hieght?
08-05-2004, 09:01 AM | #7 |
Yup, long enough to set ride height where you want it. Be sure your springs are long enough to be under some preload also. It will probly take some work to find the right amount of spring rate and preload but I bet you can get it dialed in.
