07-17-2006, 10:30 PM | #1 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
| Diff Reversal
I've searched a bit, and I can't seem to find any good pics of the inside of a TXT axle. What I'd like to know is - can you flip the diffs around inside the axle to make the wheels spin in reverse? The reason I ask, is I had an idea to eliminate torque twist. You'd need to run the axles off seperate transmissions. If you flipped the diff in the rear axle, you'd have to run the rear tranny in reverse to spin the wheels forward. The front axle and transmission would run as usual, and this would make each axle/tranny pull on the chassis in opposite directions, canceling each other out in terms of torque twist. I suppose each axle may still try to lift a tire on opposite corners, but I think the weight of the rig would help keep that to a minimum. I know with proper chassis and suspension setup this wouldn't be necessary, but it is just something I have been thinking about. And with seperate transmissions and speed controllers, digs would be easy as pie. |
07-17-2006, 10:55 PM | #2 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
sounds really really complicated and heavy. a shafty clod
07-17-2006, 11:07 PM | #3 |
Unnecessary? Perhaps. But it isn't that complicated - you just need to flip the diff in one axle, and run two trannies and speed controls. And with each tranny only running one axle, you could get away with smaller units like a Pede or a Stealth. I suppose it is a lot like a "Shaftie Clod". I like the scale-ness of shaft driven trucks, and you could do both front and rear digs very easily.
07-17-2006, 11:18 PM | #4 |
Rock Crawler Join Date: Feb 2006 Location: glastonbury
the biggest problem that torque twist causes is on the chassis. you can get rid of most of your torque twist many ways. i usually love crazy builds but this one might just be a little too out there. |
07-18-2006, 09:42 AM | #5 |
Quarry Creeper Join Date: Mar 2004 Location: Central NY
I think you can do it with TwinForce axles; I remember putting the gears in wrong once which made the rear tires spin backwards. Doing that and then flipping the axle upside down should work. You wouldn't be able to do this with a TXT though since the gears only go in one way.
07-18-2006, 09:43 AM | #6 |
if your hearts set on doing it. just use maxx axles. you absolutely can flop the diff in them
07-18-2006, 01:53 PM | #7 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
one idea i have been playin with is adding a gearbox to both txt axles to allow digs and whatnot (clod style)... to make your life easy... just switch the leads on the motor and make the motor run backwards... and no... there is no way to flip the gearing around to make it run backwards (in the axle)...
07-19-2006, 11:42 AM | #8 |
Newbie Join Date: May 2005 Location: P-land
I'm still pushing the 'gear down the diff' way of doing it, to get rid of some of the torque transmitted through the driveshaft. 2:1 gear reduction in an axle for a crawler really isn't enough. My $.02 anyway. I may get around to it someday. It's just a matter of finding 2 gears that fit.
07-19-2006, 11:47 AM | #9 | |
RCC Addict Join Date: Jan 2005 Location: Germany north
07-19-2006, 04:02 PM | #10 |
Quarry Creeper Join Date: Feb 2006 Location: Angier N.C.
Owning a Jugg and knowing it's insides like I do, I agree with TwistedXT, I can't see any way of turning the diff around. The "hoghead" is molded in such a way that the diff can only go in one certain way.
07-19-2006, 04:46 PM | #11 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
07-19-2006, 05:02 PM | #12 |
Really? Cool! Maybe that is why I don't have such drastic twist as others I've seen. I just installed my tranny backwards because of space issues. Very cool!
07-19-2006, 05:38 PM | #13 | |
It is and I have no clue why it works.......I just stumbled upon it reworking a rig for a guy | |
07-19-2006, 05:43 PM | #14 |
Thanks for the info. Looks like I may go with a Maxx hybrid style setup anyway, to save some cash.
07-19-2006, 08:57 PM | #15 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
its called counter spin drive and i think its mainly done on tlts.
