Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Not so low TXT
Old 01-17-2005, 10:19 AM   #1
Default Not so low TXT
Well I've changed a few things. I changed the stock TXT ballends to 3mm Dubro's drill out and tapped to 4mm. That lengthened the WB a bit. I also moved the upper shock mounts inside the frame and further from the tranny.
rig stats have been updated
rckjeep is offline   Reply With Quote
Old 01-17-2005, 10:27 AM   #2
MODERATOR™
EeePee's Avatar
Default Re: Not so low TXT
Looks good as usual.
The inboard shock mount allow a little more flex?
A little less bind? Both? Neither?
EeePee is offline   Reply With Quote
Old 01-17-2005, 10:36 AM   #3
Diggin' the new SCX10 II!
badger's Avatar
Dude, your about a slow as a tortoises having sex with your projects!
Get busy punk! You have 1 week to finish your scale tuber or I am cutting you off from the Internet and Insane!
Don't make me use my pimp hand!
badger is offline   Reply With Quote
Old 01-17-2005, 10:41 AM   #4
OK OK, you try building a tube bumper for a blazer, a tubular front clip for a Land Cruiser, a scale buggy, fixing my 1:1 Jeep, playing Insane, making the woman happy, starting a business, and being your tube whore. it takes time. Oh not to mention being a dad.
Old 01-17-2005, 10:45 AM   #5
badger's Avatar
Who said you need to do all that? I only approve of being my tube whore!
I guess wheels, groupie and I will just go scale crawling without you!
Old 01-17-2005, 10:53 AM   #6
How about you come over watch the boy this week and I'll finish the buggy. Bring rubber gloves his diapers can be really nasty. Thanks Badger it's going to help me out a lot. Oh and I ordered you $53 worth of tubing last night.
J/K I ordered you some cro-mo and some 3/16" stainless tubing for the scale bumper. I think we can silver solder it. and it won't need to be painted.
Old 01-17-2005, 11:13 AM   #7
MODERATOR™
EeePee's Avatar
Old 01-17-2005, 11:55 AM   #8
sorry EP, i didn't see that. more flex. but you can't go too far in. it will not be stable nor would the shocks be in the axle path.
Old 01-17-2005, 12:19 PM   #9
MODERATOR™
EeePee's Avatar
How's the twist?
(I've been not using springs lately, all droop travel, but it's time to change.)
Old 01-22-2005, 10:16 PM   #10
it's only noticeable climbing a steep incline. I'm going to use stiffer oil and maybe springs.
Old 01-22-2005, 11:27 PM   #11
badger's Avatar
You mean thicker oil and stiffer springs?
