12-09-2006, 02:56 PM | #1 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
| Pinion come's off
Hi When i go rock crawling and get my wheel stuck.i apply a little bit more throttle ond and my motor pinions come lose. Can somebody help me out? Any info give would be appreciated Thanks james Last edited by Moondust1950; 12-09-2006 at 03:04 PM. Reason: spealt wrong |
12-09-2006, 03:01 PM | #2 |
It skips contact with the spur? Or it slides in the plane of the motor face?
12-09-2006, 03:03 PM | #3 |
No the pinion is attached to a gd600 which go's to the spur gear. that is the one that come's off
12-09-2006, 03:12 PM | #4 |
RCC Addict Join Date: May 2006 Location: Aroostook county
Loc-tite |
12-09-2006, 03:26 PM | #5 |
allready tryed it |
12-09-2006, 03:55 PM | #6 |
Sounds like your set screw is coming loose. Only two things to fix that....Locktite and a little elbow grease.
12-09-2006, 04:00 PM | #7 |
OK thanks for the help mate i will give it another try and let you know how it goes Thanks again james |
12-09-2006, 06:05 PM | #8 |
Quarry Creeper Join Date: Jul 2006 Location: I didn't build that course.
mayb try using tire glue instead of lock tite
12-09-2006, 06:09 PM | #9 |
If the lock tight doesn't work i will try the tyres glue Thankyou james |
12-10-2006, 06:25 AM | #10 |
Is there a flat spot on the GD600 for the screw?
12-10-2006, 06:32 AM | #11 |
no just round
12-10-2006, 10:13 AM | #12 |
Rock Crawler Join Date: May 2006 Location: san diego
file a flet on the shaft for the set screw to hold on to |
12-10-2006, 10:15 AM | #13 |
| ok i will do that |
12-10-2006, 02:20 PM | #14 |
Landy mad Join Date: Jun 2005 Location: Newcastle, England, UK
How about taking the file a flat suggestion one step futher. Mark on the flat where the screw will sit then drill a hole through the GD600 shaft and fit one of the pins that come with the traxxas output yokes. I would check to make sure the thread in the pinion is the same as the output yoke pin before drilling the shaft. It's basically the same modification as you would do on a TLT axle pinion or Stampede gearbox output shaft |
12-10-2006, 02:23 PM | #15 |
Thanks ian i will try the filing the output shaft down first if that doesn't work i will trying drilling it |
