Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: how to narrow txt-1 wheels with 2 cuts and no glueing
Old 02-10-2005, 09:56 PM   #1
Default how to narrow txt-1 wheels with 2 cuts and no glueing
step 1 dismount wheels by methog of choice
step 2 take ordinary, run of the mill snuv nose pliers
step 3 eyeball the width of the bead( or meaur if you feel like it
step 4 take ordinary pliers and grab ahold of te "vanes" or crossmembers and proseed to rip/tear out the aforementioned eyeballed width
step 5 take hacksaw/dremel/stake loaf o bread and remove the old channel where th bead sat. savine the old inner lip as the new uter lip
step 6 glue on tires
you now have a wheel that is approx/ 1.5 inches narrower and you didn't sacrfice ant strutural integrity. and you didn't change the offset or backspacing
pics in a few
CaptainSafety is offline   Reply With Quote
Old 02-10-2005, 10:42 PM   #2
MODERATOR™
EeePee's Avatar
If I understand your method, it's the same thing I did.
And this is the result after some use. All four wheels are like this.
EeePee is offline   Reply With Quote
Old 02-11-2005, 11:03 AM   #3
Man is that booty fab method. And EP My rock rings would solve that problem. But I ran narrowed TXT wheels without rock rings for a long time without any issues. Though my method to narrow them was a tad more civialized.
rckjeep is offline   Reply With Quote
Old 02-11-2005, 12:02 PM   #4
true, but when you have a pair of pliers and ca glue ya do what ya gotta. plus i am cheap, plus i am lazy. as a matter of fact i should have just typed cheap and lazy cause it was shorter.
I have a dremel but i ran out of cut off wheels and those thinks are like 8 bucks for 5 man.
Old 02-11-2005, 12:12 PM   #5
Lol
Old 02-11-2005, 01:35 PM   #6
Diggin' the new SCX10 II!
badger's Avatar
Why don't use just chew off the sections of the rim you don't want? You probably get similar results.
badger is offline   Reply With Quote
Old 02-11-2005, 06:58 PM   #7
well i got them done. they look a lot better and there holdin up fine. i took a permanant marker and blacked out the lip. i guess shoul take some more pics.
Old 02-12-2005, 12:57 PM   #8
well all i can say is wow. the narrowed tires made a world of difference. also i put in the 9 tooth pinions and again WOW. run times tripled lol.
Old 02-12-2005, 03:53 PM   #9
RSI
this has been posted before...
RSI is offline   Reply With Quote
Old 02-12-2005, 03:58 PM   #10
