03-25-2007, 08:28 PM | #1 |
Rock Stacker Join Date: Sep 2006 Location: Iowa
| b ody lean torque steer
So I finally have my Jugg crawler crawling but when I give it a lot of trigger the body leans hard to the right. My question is what shocks should I put the heavier springs and higher weight shock oil? I think that when I get his tamed I should be ready to go up stairs with no problem at all. Any help for a newbie? Thanks Maxx Runner |
03-25-2007, 08:30 PM | #2 |
What weight oil you running now? Try a stiffer rate spring on the right rear. I'd recommend up to 100 weight shock oil. |
03-25-2007, 08:41 PM | #3 |
I don't know shat weight oil is in the shocks they are the std. plastic t-maxx shocks with the red springs. So all the stiff springs and shock oil should be in the right rear?
03-26-2007, 07:03 PM | #4 |
Pebble Pounder Join Date: Oct 2006 Location: Enterprise
Put a stiff racing spring on the right rear
