Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: What to do?
Old 05-01-2007, 04:59 PM   #1
Default What to do?
I just picked up all these parts for a screaming deal-
Intigy 55t motor
Tekin Rebel 2 SC
Hitec 265 servo
Tranny and drivelines
Airtronincs Control
4 TXT axles
2 Batteries
New rims and tires
And one beat to hell crawling frame.
Im new to RC crawling, i had the big nylint crawler, but alas it broke! But i got all these parts and want to build a decent rig. It moves in its current form but the suspension links are crappy and poorly designed. What kind of frame/suspesnion would you recommend as im not ready to fabricate my own just yet. Thanks.
Krawln68 is offline   Reply With Quote
Old 05-01-2007, 06:29 PM   #2
whats wrong with the tuber i would just fix that it looks pretty nice if the links are that bad i would just make new ones and fix what you have looks like a killer start
sloppy is offline   Reply With Quote
Old 05-01-2007, 07:53 PM   #3
Well the suspension binds and the links hit the shocks. If there was more of the original frame left it would be ok, but what is left is half-a** soldered and JB welded!
Old 05-01-2007, 08:14 PM   #4
Keep it real
Tanis's Avatar
I would suggest Bender's SW2 chassis.
Tanis is offline   Reply With Quote
Old 05-01-2007, 09:19 PM   #5
Can you go to a 16" WB with the SW2? Thats where it sits currently sits and looks good. It seems most are running that chassis at 14" and i think it would put the tires a little to close together.
Old 05-01-2007, 10:58 PM   #6
Keep it real
Tanis's Avatar
Bender ran a super with the SW2, using clod axles with an 18" wheelbase. Adding a tranny and drivelines shouldn't be much of a deal. Search "delrinator" in the clod forum.
Old 05-04-2007, 10:21 AM   #7
Well i disassembled it today and the frame is history. I like the SW2 chassis but there is no provision for the stock tranny. The crawl ratio was fine before i took it apart, so i would like to keep the tranny instead of swapping to a stampede or R2. The steering servo isnt very strong so i would like to save the cash for that anyway. i tried searching ebay for stock chassis, but none available right now. Looks like i may have to build my own after all.
