07-01-2007, 07:58 PM | #1 |
Rock Stacker Join Date: Sep 2006 Location: Iowa
| broke pinion shaft
So what do you do when the pinion shaft breaks at the driveshaft. I had it drilled for revo shafts and broke at the drilled hole. I can't seem to find any repacements online, so can any of you help me find or fix this problem? Any links to replacement parts? Any help is welcome! MaxxRunner |
07-02-2007, 10:17 AM | #2 | |
I did this a few years back too. I actually rebuild the broken shaft. I pulled the bearings off of it, and set it into a clamp. I then added a tack weld upon tack weld. Sounds ghetto but it worked great. I actually made the pinion shaft a bit larger in diameter too. After some handy dremel work you couldn't even tell I had done anything to it. I even drilled a new hole to fit the sliders back on. I'll have to figure out where I have those images saved. | |
07-02-2007, 08:18 PM | #3 |
thanks for the reply that is what I was planning on doing but didn't know if I could score some new parts from someone here. MaxxRunner |
07-09-2007, 07:28 PM | #4 |
Well I had it welded and turned down to size in a lathe first rock it snapped again. Any other fixes? MaxxRunner |
07-11-2007, 11:13 PM | #5 |
07-12-2007, 12:07 PM | #6 |
Took to a welding shop and done by a certified welder. Turned down on a lathe and re drilled for the grub screw. First rock it was on snapped like a toothpick. I have since located replacement shaft and am waiting on delivery. MaxxRunner |
07-12-2007, 02:57 PM | #7 |
| Send me your broken ones and I'll fix 'em right I'm a certified booty-fabber and make things work.
