07-22-2007, 08:58 AM | #1 |
Rock Crawler Join Date: Aug 2005 Location: White Lake
| GD-600 mounting
never done a gd-600 gear reduction before and how do you modd them to fit the txt trans. Will it stopp stall with 55t lathe motors with moab xl?
07-22-2007, 09:07 AM | #2 | |
Rock Crawler Join Date: Apr 2004 Location: toolsa, jokelahoma
Installed a GD-600 gear reduction Last edited by mrmaxxman; 07-22-2007 at 09:13 AM. | |
07-22-2007, 10:33 PM | #3 |
Rock Crawler Join Date: Apr 2007 Location: Hawaii
I recently installed one(does the chassis look familiar Ron?(mrmaxxman)) and it's not hard at all. I disassembled the GD and chucked the output shaft in a drill and ground it down with a file. I was careful not to nick up the shaft but it really doesn't matter that much because it rides on bearings. Then I used a dremel to ground down the housing where the pinion shaft is to fit in the TXT motor plate. I also ground down the little "bump" in the TXT plate itself. Depending on how you want the GD oriented; sideways like the picture,sorry it's so blurry, it's pretty much bolt on(I removed a little tab on the GD that was blocking the screw hole to mount the plate to the tranny); or up and down the you'll have to drill holes in the motor plate. The only other thing to remember is if you mount the tranny in the stock direction with the motors in front the motor rotation will need to be reversed to compensate for the GD reversing the rotation of the drivetrain. |
07-30-2007, 11:17 AM | #4 |
ha ha sure does, |
07-30-2007, 10:39 PM | #5 |
Pebble Pounder Join Date: Jun 2004 Location: burton
question? is it better to use a bigger gear on the gd600 shaft or the motor
07-30-2007, 11:37 PM | #6 | |
It depends on the gear ratio you want. There's a sticky in this section with a breakdown of the final drive ratios. Remember the GD uses a 48pitch pinion instead of the TXTs 32pitch pinion. There are 3 sizes available specifically for the GD, 18t, 15t, and 12t. Also if you buy a GD new it will come with a 18t pinion for a 2.5 :1 gear reduction, a larger gear than that and your pretty much negating(sp?) the effects of the GD. I run a 18t 48p pinion on the motor and a 12t 32p pinion on the GD for a final drive ratio of 106:1. I haven't tested it yet but most people say you want the final drive ratio around 100:1, but it really depends on your driving style. | |
07-31-2007, 02:25 AM | #7 | |
Newbie Join Date: Dec 2006 Location: Iron Range
07-31-2007, 07:48 AM | #8 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
I have 15t pinions with 5mm bores on mine. works dandy. The gd's were originally installed pionted up, I pointed them down, which meant I had to install the gear boxes on the motor plate, put the motor plate into the tranny, then bolted the motors to the gear boxes using allen head screws and a modified allen wrench. a lot more work, but it lowered the CG by dropping the motors almost 1-1/4"
