04-03-2005, 03:10 PM | #21 | |
Rock Crawler Join Date: Jul 2004 Location: Mt.View CA
Remeber if you want to run kongs you'll have to pay the price,so get those moabs on there | |
04-04-2005, 04:26 PM | #22 |
Rock Stacker Join Date: Apr 2004 Location: FRONT DIGGING YOUR MOMS YARD
| Can You Say Sweeeeet
I put the Moabs on and a body.The servos are sticking out but i think i can deal with it.I think I have it dialed in petty good. The only thing i don't really like is the way the gears whine through the chassis and body. It reminds me of my 1:1 jeep when the Terra Low 4:1 transfer case is in low range. I had to change the front servo from an Airtronics 358 to a Hitec 5945. I think the Hitec is a stronger servo.Now i need to get together with somebody so i can put the smack down on them Check it out. Now its time to finish up another project truck
04-04-2005, 04:28 PM | #23 |
| more
txt and more projects
04-04-2005, 04:29 PM | #24 |
| more
more
04-04-2005, 04:29 PM | #25 |
Rock Stacker Join Date: Feb 2005 Location: Heber, Utah
Great job, very clean. Have you narrowed your rims yet?
04-04-2005, 04:41 PM | #26 |
I can't tell possitively, but it looks like you've mixed and matched the steering hubs. The steering arm has a higher location one way. It looks like the driver's front is high, and the passenger front is low. And I don't mean the way that you mounted your steering links. Might be the camera? But it does make a small difference in the clearance of the drag link. Otherwise, it looks great. |
04-04-2005, 05:04 PM | #27 |
Pebble Pounder Join Date: Jun 2004 Location: burton
you only have one light on it might want to get it fixed before you get a ticket LOL http://www.rccrawler.com/forum/attac...achmentid=1271 |
04-04-2005, 05:18 PM | #28 |
| good catch
You are right about the steering knuckle. I did that so I could mount the drag link to the rear of the servo arm.It rubbed with the other knuckle. I am going to make a z shaped draglink. I went to the trails and did some testing. I really like the wheelbase, never flipped backwards and climbed some big steep lines. I will need to get used to the way the suspension loads and unloads under torque. i also don't know if i'm going to keep the 4ws because the rearend sometimes flops to one side when side persure applied under load it rights itself, but by then my line is compromised. The wheels are narrowed 1" and the foam was cut in half and glued to the wheels. I THINK ITS READY TO KICK SOME DIGLER A$$ oh sorry i must of been dreaming lol haha
04-04-2005, 05:30 PM | #29 |
RCC Addict Join Date: Jun 2004 Location: Bruiser Heaven!!!!
that thing looks sweet man and nice paint job too.
04-04-2005, 07:13 PM | #30 |
Pebble Pounder Join Date: Dec 2004 Location: Delaware A Place With No Rocks!
i had the same problem with my rear steer so i ripped it out and now it can climb much beter Just lost some turn radius |
04-04-2005, 09:09 PM | #31 |
Quarry Creeper Join Date: Jan 2005 Location: Denver, CO
yes i can: Sweeeeet |
04-04-2005, 11:21 PM | #32 |
Quarry Creeper Join Date: Jun 2004 Location: Ventura
the pimp sticker is classic!!!
04-05-2005, 01:35 AM | #33 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
EJEEP, I merged this thread with your other two. Let's try and keep the build-up of your TXT in one thread. |
04-11-2005, 03:08 PM | #34 |
Rock Stacker Join Date: Nov 2004 Location: right here
i like that suspension setup, never seen it before. looks great.
