04-18-2005, 06:56 AM | #1 |
Rock Stacker Join Date: Apr 2005 Location: Tokyo, Japan
| Newbie: TXT-1 servo stock gear stripping
guys.. I just completed fixing up the txt, and now, cant get the servo gears to work!! Servo used: Hitec 645mg The stock plastic servo saver gear (stock tamiya which comes with the kit, #Q part) keep on stripping. i have to remove the servos and readjust again and again everytime it goes out running. is it recommended to use the stock #Q gearing parts? What modification is necessary to keep it running with zero problems on steering? Pls advice as this problem is ruining the otherwise fun TXT-1!! :neutral: |
04-18-2005, 07:26 AM | #2 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
The Kimbrough servo savers are the most common ones used on larger trucks. But make sure you get the large saver made for gas cars. I am to lazy to search for the part number right now. GS racing also makes some decently strong servo savers, as well as Ofna. The other option is to just run a aluminum servo horn, and skip the saver all together. But this can lead to stripped servo gears, even with the metal gears. I just stripped my first servo gear on a 645mg the other day :-P |
04-18-2005, 09:28 AM | #3 |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
None of the adapters that come stock with the TXT have the correct # of splines. Get a Kimbrough #124 (the black one). It'll come with the correct adapter to use with the Hitec servos. I believe it's 25 splines. I used to use it on mine, but still had issues when turning, so I switched to the standard horn that comes with the servo. The plastic arm *should* break before you strip a gear. |
04-25-2005, 09:14 AM | #4 |
Thanks for the help guys.. highly appreciated. |
04-26-2005, 10:50 AM | #5 |
Rock Stacker Join Date: Apr 2005 Location: Rock Haven
I'm using Airtronic VB servos both front and rear and when the truck is on the floor, it hardly turns when stationary. Thats for 13kg of torque. I was thinking of using the stock Airtronic servo saver too. Why'd you guys think?
04-26-2005, 11:00 AM | #6 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
i dont use servo saver on my txt streeing they take to much power from the servo.
