Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Juggernaut beveled gears gone
Old 02-05-2012, 03:41 AM   #1
Default Juggernaut beveled gears gone
I just got what I can gather is a 1st model juggernaut, and the rear end won't pull. Took it apart and the gears on top are gone. I've found some on eBay, but I think they are the gears in the lower part of the diff. I really like this truck, and sucks I can't run it like it should. Thanks
oojamison is offline   Reply With Quote
Old 02-08-2012, 10:44 AM   #2
Default Re: Juggernaut beveled gears gone
tamiyausa.com and download the manual for the jugg and txt and see which yours is, then you will have the proper part numbers
william g is offline   Reply With Quote
Old 03-01-2012, 12:25 PM   #3
Let me know if you need the diff gears .. i think i have a few sets left .. and a built set of jugg 2 axles ...
Rc moneypit is offline   Reply With Quote
Old 03-05-2012, 05:06 PM   #4
yea i had the same problem with my jugg 1 as well then i went to a txt axle set up lol..
blur85 is offline   Reply With Quote
Juggernaut beveled gears gone - Similar Threads
Tamiya Juggernaut asc6000 General Crawlers 3 07-29-2011 10:31 PM
Heavy Duty Beveled Ring-Pinion easleycrawler Axial AX-10 Scorpion 4 04-04-2010 09:19 AM
juggernaut 1 value? crawl Tamiya Txt-1 and Juggernaut 3 09-24-2008 05:42 PM
