Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: bearings
Old 05-11-2005, 11:58 PM   #1
Question bearings
Tamiya calls for a 6x11 for the jugg2/txt in the tranny and axles . Ebay has bearing "kits" for sale for these trucks but they all seem to have 6x12 and other sizes for the truck but no 6x11. Now how important is it to make sure it is 6x11 over 6x12. Will the 6x12 just not fit or will it fit sloppy and not work like it should. I dont want to make a mistake and order some bearings and not be able to use them in my jugg1 upgrade. I ordered all the other parts needed to make the axles jugg2/txt compliant but need to know for sure if i "HAVE" to use a 6x11 over the 6x12 bearing for the axle and in the tranny.
powertuned is offline   Reply With Quote
Old 05-12-2005, 11:57 AM   #2
FrankyRizzo's Avatar
I just went through this myself. 6x12 is for the axles and hub carriers. 6x11 is for transmission internals and for the gear reduction units on top of the axles.
FrankyRizzo is offline   Reply With Quote
