Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Tamiya XC/CC01
Thread: UTRCRC Scale Adventure II CC-01
Old 03-27-2009, 08:02 PM   #1
'08 2.2 National Champ
Just Zach's Avatar
Default UTRCRC Scale Adventure II CC-01
I figured I'd post up my Pajero for the UTRCRC Scale Adventure II
http://utrcrc.freeforums.org/utrcrc-...e-ii-t158.html
Just a few little mods. Thanks to PinchFlat, Kaetwo, and JSSuper for mod help. I'm really novice when it comes to these.
Specs
Tekin FX-R
TowardPro MG946 servo
3s Thunder Power lipo
75t hand wound integy motor
One off Create-a-Crawler 1.9 beadlocks Narrowest offset 1.9 out there.
Losi Basher Tires, for now
CS/CC Ball Bearing steering kit. Awesome kit!
Yeah Racing light kit.
Only mods I have done are a bit of grinding for more suspension and steering and 1/8" front body lift.
I had a Pajero before but overall I didn't do much to try to make it perform better and didn't like it. With a few quick mods they are very capable and fun. I was blown away by one of the lines I took with it today.
Just Zach is offline   Reply With Quote
Old 03-27-2009, 10:03 PM   #2
Very nice. How do you like those tires? I like the color combo
tom tom is offline   Reply With Quote
Old 03-27-2009, 10:03 PM   #3
NBRCC
hellbentrodder's Avatar
Looks really good
hellbentrodder is offline   Reply With Quote
Old 03-27-2009, 11:38 PM   #4
I am a Liar!
pantablo's Avatar
those tires are supposed to be the same compound as the 2.2 rock claws so they're going to be very grippy...
nice looking paj. unusual color choice but nice change of pace. I like it.
pantablo is online now   Reply With Quote
Old 03-28-2009, 07:57 AM   #5
Just Zach's Avatar
Thanks guys. I think the color turned out really good.
They are the Losi Blue compound. They grip quite well too. They do rub a good amount but its not bad enough to take them off. The front body lift helped them not rub as much.
Old 03-28-2009, 06:25 PM   #6
R/C Investor
sgil2001's Avatar
"CS/CC Ball Bearing steering kit."
Could you please elaborate? I'm not familiar with this. I'm just getting ready to start my Pajero and I want to do it right.
thanks.
sgil2001 is online now   Reply With Quote
Old 03-28-2009, 06:38 PM   #7
Just Zach's Avatar
JSSuper makes them, kind of. He said its pretty much just for guys in Utah. You could try pm'ing him and see what he says though.
Basically though is a kit that converts steering into a ball bearing system instead of a bushing system that wears out.
Old 03-28-2009, 11:27 PM   #8
Fighting off whores
kaetwo's Avatar
Awsome rig Zach. I'll have mine finished up soon and posted as well.
This next Adventure should be a ton of fun and with everyone having he same rigs, it should be very competative.
I can't wait!
kaetwo is offline   Reply With Quote
Old 03-28-2009, 11:33 PM   #9
Just Zach's Avatar
I agree, its will be fun to have a level playing field. I can't wait to see what you have in store
Old 04-06-2009, 09:36 PM   #10
Just Zach's Avatar
I am having an absolute blast with the Pajero! Here's a video of Big Bear's and my Pajeros running
http://www.hobbyzip.com/videos/805/b...e-pajeros.html
Old 04-06-2009, 11:56 PM   #11
I am a Liar!
pantablo's Avatar
thanks.
while not a kit, here's a How-To converting the steering bellcrank to ball bearings.
http://www.scale4x4rc.org/forums/showthread.php?t=6780
Old 04-07-2009, 11:50 AM   #12
✘ ɹǝʞɔɐʇs ʞɔoɹ ✘
akguanja's Avatar
i like the color of it and the video was pretty sweet.
wish we could get the guys to all get one type of truck.
akguanja is offline   Reply With Quote
Old 04-07-2009, 01:50 PM   #13
Fighting off whores
kaetwo's Avatar
It's tricky to get the group to agree on a "one type" of rig but it worked out well for us. We started our Adventure Series for 2009 with a pretty generic class and from there guys where more open to the idea of a more spec type class. Having a more level playing field should be a ton of fun
Old 04-07-2009, 08:07 PM   #14
Nice ride. I like the steering adaptation to bearings...way cool..
on the subject of everyone having the same ride...if they are all different, you can see what works going over different objects..if you all had the same truck, you would be getting stuck on the same thing.
squatch71 is offline   Reply With Quote
Old 05-31-2009, 11:04 PM   #15
Just Zach's Avatar
After the rediculous beating Mike and I gave to these Saturday and some not so good chassis mods I had to figure out a new front body mount, because it was no longer there
I came up with this simple idea and it also gives the CC-01 a huge approach angle improvement. I just cut off what was left and took some L channel and bolted it to the front of the chassis. It was really easy to do, I just lined up the bottom of the channel with the line that goes accross the chassis for the proper height. I should have moved the mount out a little in the first place but I had a hard time figuring out how far to go so I just used some spacers afterwards to get it right.
I'm going to put some sort of skid on it to look better but this is what I cut off.
Check this compared to a stock!
