Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Tamiya XC/CC01
Thread: CC01 Body lift
Old 05-22-2009, 09:48 PM   #1
Default CC01 Body lift
I just installed 1.9 flat irons on my Jeep CC01, and I am wondering the best way lift the body for more tire clearance?
Johnny Ringo is offline   Reply With Quote
Old 05-22-2009, 10:45 PM   #2
I don't have a pic at the moment but I turned the front body mount upside down and put a small washer between the mount and the chassis on each screw for the front mount, for the rear I drilled two new body mount holes under the original holes just high enough to clear the bumper, but searching will find even more options I imagine.
crawleR07 is offline   Reply With Quote
Old 05-22-2009, 10:49 PM   #3
I am a Liar!
pantablo's Avatar
^^thats how you do the body lift. then there's the chassis lift too...
slide about 1/8" worth of spacers/washers between the chassis mount points and the chassis itself.
sorry for the fuzzy photo but you can see one near my thumb. at the front there are 5 points that I can think of where the plate (the one that holds the lower A arms on) bolts to the chassis. then on the back you need to spacer the link mount points and shocks also.
not sure if thats all there is to the chassis lift as mine was done when I got it.
pantablo is offline   Reply With Quote
Old 05-23-2009, 01:00 AM   #4
31st place in 2006 Nats!!
toyofast's Avatar
The Flatirons fit pretty good on my Pajero bodied CC-01.
toyofast is offline   Reply With Quote
